12-08-2006, 06:07 PM | #1 |
Pebble Pounder Join Date: Nov 2005 Location: N. Arkansas
| weird glitchy-ness
I have been having problems with my TLT glitching when I give it throttle. I am running TQ3 radio gear, novak XRS esc, Futaba servos and a integy 55t motor with a 20 tooth pinion. Sometimes when I give it throttle it will just stop and sometimes it will go to full throttle forwards and even backwards. It is driving me insane. I have two guesses. First, the crystal is touching the aluminum frame, and second, the battery sat for 9 months and it might not be holding enough voltage. Deans connectors throughout. One more thing, when I pick up the truck it never glitches. |
12-08-2006, 06:50 PM | #2 |
Well, two things that come to mind is to make sure the antenna isn't touching any metal and maybe try installing capacitors on the motor.
12-08-2006, 07:29 PM | #3 |
thanks for the info.
12-08-2006, 09:46 PM | #4 | |
Nah,seriously,if it doesn't glitch after you pick it up,theres abviously something touching while the weight is on the truck. You pick it up and the connection causing the glitch goes away,follow what I'm saying. You might look at everything and you might find a tiny piece of bare wire thats barely kissing the chassis while it's on it's own weight. Just an idea,hope it helps | |
12-08-2006, 09:49 PM | #5 |
the rx wire is hitting the frame a little but its not bare. I see where your coming from.
12-08-2006, 09:57 PM | #6 |
its not the rx wire, its not touchin the frame. It is starting to get annoying.
12-08-2006, 10:05 PM | #7 |
Unplug each servo or esc individually and see if it stops. sometimes a bad servo or ESC can cause it.
12-08-2006, 10:19 PM | #8 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
I had a simular problem with a tq3 and xrs only I was using a hitech servo. It would glitch randomly I nstalled a reciever pack and the problem went away Devlin |
12-09-2006, 07:07 AM | #9 |
I wanna be Dave Join Date: Mar 2005 Location: Hiding from Goodall
If it runs just fine when you pick it up then to me it sounds like you have power supply issues and the XRS can't handle 2 servos AND moving a rig around. I would bet money a RX pack would fix your problem
12-09-2006, 07:28 AM | #10 | |
12-09-2006, 08:32 AM | #11 |
I was thinking that yesterday. Fudge, there is no chance in hell the LHS will have anything resembling a receiver pack. Wonder if they have battery bars....now is as good a time as any to make my first battery pack, haha. I have been planning on running a rx pack regardless, but just havent ordered it from cheapbatterypacks.com Thanks for the help guys.
12-09-2006, 08:51 AM | #12 |
Rock Crawler Join Date: May 2006 Location: United Kingdom,Scarborough
i have a http://rcsiden.dk/images/80576_01.jpg Which i would trade for a aluminium servo arm or $$ For a extra $7.00 i will throw in 4 1200mah batterys rechargable for it Last edited by Moondust1950; 12-09-2006 at 08:55 AM. |
12-09-2006, 08:55 AM | #13 |
Thanks for the offer, but it would take longer to get one from the UK than it would to have one made here.
12-09-2006, 09:00 AM | #14 |
ok |
12-09-2006, 10:53 PM | #15 |
well the LHS didnt have a 5 cell receiver so I made my own with some AA's and some stuff from radio shack. And now I think I fried the esc cause nothin is workin. the ESC powers up but nothing happens.
12-09-2006, 11:14 PM | #16 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
I was going to ask if you'd made sure the RX antenna hadn't been cut somehow. The antenna on Ralph got pinched between the frame and the rocks...cut it. I had the same issues. |
12-09-2006, 11:50 PM | #17 | |
12-10-2006, 12:12 AM | #18 | |
12-10-2006, 09:50 AM | #19 |
no:-( (cue sad music) |
12-10-2006, 09:54 AM | #20 |
So when you plugged your rx pack your ESC does nothing? Try plugging your rx pack into your receiver but don't turn your esc on. I have the same problem. so what i do is turn my esc off and just plug my rx pack in and it runs fine Goodluck james |
