12-11-2006, 01:45 PM | #1 |
Pebble Pounder Join Date: Oct 2006 Location: Right Coast
| lathe motor maintenance
how do you take care of a lathe motor besides using the actual lathe? i bought some comm drops, but being a motor newb, i have no clue how to use them. can someone help me out? |
12-11-2006, 02:03 PM | #2 |
I've never used comm drops, but if you don't know, comm is short for commutator. The commutator is the copper(?) part inside the endbell that makes contact with the brushes. So remove one of the brush springs, pull the brush out and put a few drops down inside the brush hood onto the comm. I know that comm drops can make a difference when you're racing, I'm not sure about a slow speed application like crawling. |
12-11-2006, 02:35 PM | #3 |
I wanna be Dave Join Date: Jan 2004
comm drops aren't part of maintenance. They are for "extra" performance. I wouldn't use them. They glaze the comm and your brushes. The carbon will build up on the brushes even faster by using drops. When you perform maint. on the motor, take out the brushes, clean them with a good comm stick or brush... clean the comm with the brush or stick as well. Replace brushes is worn and burnt. Spray out the entire can with motor cleaner until the fluid comes out clear. Put it all back together and oil your bearings. |
12-11-2006, 02:37 PM | #4 |
You can also cut the comm when it gets worn. Keep in mind that every time you cut the comm, you reduce the diameter, which will net you higher RPMs.
12-11-2006, 02:46 PM | #5 |
Dirk is right on with this one, I advoid comm drops, I have found that they make the brushes wear alot faster and the comm too(which is bad), although I guess its a similiar theory as to using nitrous in an engine, more power but parts wear out faster.. I personally have found that with the integy lathe motors that the comm isnt very true and they need to be turned... I come from a race back ground so I machine every motor I buy right out of the package weather its a 20$ motor or a 100$ Basically you can do like already said, clean the comm and brushes with MOTOR CLEANER and a comm stick(do not use brake clean!), just remember to re -oil the bearings. technically if the brushes are BADLY worn, installing a new set wont do you any good, chances are the comm is way out of true and itll just chew up the new brushes.. Mike |
12-11-2006, 02:53 PM | #6 | |
12-11-2006, 02:59 PM | #7 | |
-Mike | |
12-11-2006, 03:03 PM | #8 | |
12-11-2006, 03:10 PM | #9 |
I gotta agree, i've owned integy's 55t and 65 t and bought 75t axioms after and could see the difference on the smoothness in throttle response, start up was also greatly improved, overall better motors. These were used on my clods.
12-11-2006, 03:39 PM | #10 |
Rock Crawler Join Date: Aug 2006 Location: On the trail
what about using motor cleaners?? after every run....or after every muddy day or something like this http://www2.towerhobbies.com/cgi-bin...&I=LXFWJ4&P=ML thanks |
12-11-2006, 05:57 PM | #11 |
Use Motor cleaners after every run that is at least dusty. That will get you longer motor life and better performance. Once again DO NOT use brake cleaner or any old solvent to clean a motor. It can dissolve or soften the winding insulation. |
12-11-2006, 06:00 PM | #12 |
Thanks guys. |
12-12-2006, 07:02 PM | #13 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Check the bearings |
12-12-2006, 07:39 PM | #14 |
Rock Crawler Join Date: Mar 2006 Location: Auburn, WA
Make sure you oil the bearings every time you clean the motor. Like these guys stated, Integy motors pretty much are the most out of round comm's I've ever seen out of the package. True them up, and add Trinity purple brush springs (the extra stiff ones), and you will basically get the same thing as an Axiom motor. If you don't have the ability to do this yourself, go with the Axiom up front. |
