12-12-2006, 08:34 AM | #1 |
Quarry Creeper Join Date: Apr 2006 Location: sacramento
| problem.....
hey guys i was testing my sw2 last night and it was tweakin out like crazy......i was running 4ws with a rooster esc, and two 645mgs. i thought the problem could be that i was running 4ws.........so i took the rear steer off. so now im just running two channels with a tq3 and its still tweakiing out worse than it was....so then i tried the battery...nope not the battery. then i unpluged the esc from the reciver so it was just the one servo hooked up.. it didnt seem to tweak at all. then i pluged the esc/motor back into the reciver and the minuite i did that it started tweakin. i think i have narrowed it down to either the motor or the esc..what do you guys think???????? chase |
12-12-2006, 08:40 AM | #2 |
Rock Crawler Join Date: May 2006 Location: United Kingdom,Scarborough
Do You have a rx pack (receiver pack) ? If you have one handy plug that into your B/C slot on your receiver. And see what happens it may be your number of amps your BEC has. |
12-12-2006, 09:08 AM | #3 |
| no im not running an rx pack so i guess i will try that..thanks
12-12-2006, 09:28 AM | #4 |
What crystals are you running?
12-12-2006, 09:47 AM | #5 |
I wanna be Dave Join Date: Sep 2005 Location: R.I.P. Chip
I had the same thing happen when I scraped a capacitor off on the rocks, Make sure they are all attached like they should be.
12-12-2006, 09:56 AM | #6 |
Pebble Pounder Join Date: Nov 2005 Location: huntsville
I had a bad 645mg make my truck do what you are describing. I could run the truck about 5 min. and the steering would start glitching, then get worse and at about 7 min. The whole thing would start glitching, rear servo, esc and all.
12-12-2006, 10:04 AM | #7 |
I asked about the crystals because i bought 4 sets of cheap 40 mhz fm crystals to run all my clods on one radio, and they all glitched, i just swapped back the original acoms crystals on my radio and receiver and no more glitching, i tried the acoms receiver crystal with their own different receiver on all the other three rigs and no glitching, at least that was my problem.
12-12-2006, 02:03 PM | #8 |
well im just running the stock crystals when i bought my tq3 of ebay....... also i probly should have mentioned this before...im not running any capacitors on my 55 lathe.....do you think thats my prob |
12-12-2006, 02:06 PM | #9 |
Yes |
12-12-2006, 02:21 PM | #10 |
ok.....one more question...do you know what size capacitators i should get for a 55t lathe and a novak rooster....i dont have any so im gona have to go to radio shack.
12-12-2006, 03:50 PM | #11 |
Newbie Join Date: Oct 2006 Location: Claremore
.1uF <---thats micro farad |
12-12-2006, 04:33 PM | #12 |
Have you used them before? There should be three in your ESC box |
12-12-2006, 04:33 PM | #13 |
I've never bothered with capacitors. And exactly what the hell is tweaking? |
12-12-2006, 04:44 PM | #14 |
just whenever i turn the truck on .....the steering just starts tweaking and the truck just has quick jults of movement back and forth..:-(
12-12-2006, 04:50 PM | #15 |
Perhaps its your receiver. Is your antenna broke on your transmitter? |
12-12-2006, 04:51 PM | #16 |
Try unplugging the servo and see if it does it. Narrow it down more.
12-12-2006, 05:08 PM | #17 |
ya i unplugged the servo and it does it..so its either the esc or the reciver.
12-12-2006, 05:12 PM | #18 |
the wire on the reciver from the antenna started to unravel from the plastic...so i put some heat shrink on it....im thinken its narrowing down to the reciver..but i put my 4 channel radio in it and it still tweaked so i still have no idea.
