02-01-2005, 09:52 PM | #1 |
Newbie Join Date: Oct 2004 Location: Yakima, WA
| ID these connectors
Does anyone know what these connectors are called and where I can buy them? The green one is on the Superbrain 969 and the others are on a Apex Sigma DC charger. I want to buy some connectors so I can make adapters to use the Apex with the 969 power supply and make a cord to connect my 969 to a 10 amp power supply I have. |
02-01-2005, 10:57 PM | #2 |
Pebble Pounder Join Date: Jan 2005 Location: Kln, HKG
02-01-2005, 11:24 PM | #3 |
Both are MOLEX Connectors. http://www.molex.com/cgi-bin/bv/mole...e=Introduction http://www.action-electronics.com/molex.htm |
02-02-2005, 03:38 AM | #4 |
Rock Stacker Join Date: Dec 2004 Location: in limbo
why not connect both chargers to the 10a powersupply? your going to run into problems using your "brain" like overheating if you want to charge with it at the same time...your going to draw the same if not more amperage running a big line like that. someone correct me if im wrong.
02-02-2005, 03:07 PM | #5 |
I want the 969 on the 10A PS so I can charge up to 5 amps on both channels. I have been using the 10A for the Apex, but now I can use the 5A PS that came with the 969 for the Apex since it can only charge one battery at a time. So if these connectors are hard to find, maybe I'll just cut them off and convert everything to Deans or Powerpoles or something else common. Anyone see a problem with that? |
