12-13-2006, 06:49 PM | #1 |
Pebble Pounder Join Date: Aug 2006 Location: Emporia
| Glitching while in water?
Waterproofed my clod basher and took it out in the mud/water today. Seems like if you let off the throtel while in water it would not go again untill I would take it out for a few seconds, no f or rev. Only thing I forgot to do was put delectrict grease on the deans for the batts. Do you think this could be the problem? Esc and rec are sealed in a plastic box with silacone, servo worked fine its packed with delec grease. |
12-13-2006, 06:58 PM | #2 |
Quarry Creeper Join Date: Dec 2005 Location: Southern Maryland
If you have a 2.4 GHZ remote and reciever that is your problem, Badger pointed out this problem before and it happens due to refraction.
12-13-2006, 07:00 PM | #3 |
Rock Crawler Join Date: Nov 2005 Location: Oak Ridge
It may have something to do with the brushes in your motors being submerged.
12-13-2006, 07:05 PM | #4 | |
12-13-2006, 07:06 PM | #5 | |
12-13-2006, 10:37 PM | #6 | |
12-13-2006, 11:07 PM | #7 |
What I meant was, if the water was dirty, it may have prevented the brushes from making a good connection with the comm. When he pulled the truck out and gave the water time to drain, they would work again.
12-14-2006, 10:13 AM | #8 | |
Quarry Creeper Join Date: Nov 2005 Location: The Great White North
12-14-2006, 01:19 PM | #9 |
The motors are some older speed gems, this might be the problem. I do have some stock tam. cans I could try just to see if it helps the problem. Thanks for the input. |
