12-14-2006, 11:00 PM | #1 |
Rock Crawler Join Date: Nov 2006 Location: Spanish Springs, Nv
| lipo pack
anyone know how long the team orion 4800 lipo pack will run in a crawler? thanks
12-15-2006, 02:58 AM | #2 |
Rock Crawler Join Date: May 2006 Location: san diego
| orion 4800 lipo
I get two hours in my tlt, revolver brushless, trekin minirage setup.
12-15-2006, 02:05 PM | #3 |
Rock Stacker Join Date: Oct 2006 Location: ezel
| power
Does the lipo battery have a lot more power and is it hard on motors and esc's like running a lot hotter. Thanks Terry |
12-15-2006, 02:14 PM | #4 |
a standard 6 cell nimh has 7.2 volts a 2 cell lipo has 7.4 volts. so yes it is a little faster and runs a little hotter but only a little. should cause no problem. a 3 cell lipo has 11.1 volts and is a bit faster and a bit hotter might be to hot for some setups. |
12-15-2006, 07:48 PM | #5 |
Quarry Creeper Join Date: Jan 2006 Location: Orlando
Also, a word of caution...if you're planning to use a Lipo, be sure you either have a low voltage cutoff (LVC) built into the ESC or an external LVC to keep your Lipos from being potentially damaged.
12-15-2006, 08:50 PM | #6 |
| lipo pack
I have a rebel 2 in my CFNN, and Novak brushless in my TXT. I plan on using the lipo in both.
12-15-2006, 08:52 PM | #7 |
| lipo
would I still need a reciever pack for the servos?
12-15-2006, 09:27 PM | #8 | |
12-15-2006, 09:31 PM | #9 | |
12-16-2006, 08:16 AM | #10 |
| fan on esc
Does anyone run a fan on their esc?I have the original rebel and it is one of the first ones that come out has always been a good esc but have always run a small fan on it,i can run a batt.thru it and its still very cool i run a traxxas 2055 on it, will it power a hitec 645 ok. Terry |
12-17-2006, 04:51 PM | #11 |
| lvc
do you know where I can find a LVC? thanks
12-17-2006, 05:25 PM | #12 |
| www.maxamps.com under their Lipo Car Packs section
12-17-2006, 06:01 PM | #13 | |
Pebble Pounder Join Date: Feb 2005 Location: Pioneer Valley
http://www.dimensionengineering.com/LipoShield.htm Easy-peazy to setup and works great. I used one on one of my heli's that doesn't have an LVC built into the ESC. The soft cut-off is great for getting back down to the ground before you run out of juice. - Chris | |
12-17-2006, 06:12 PM | #14 | |
http://www.bphobbies.com/view.asp?id...71&pid=W150125 http://www.all-battery.com/index.asp...OD&ProdID=1373 | |
12-17-2006, 07:12 PM | #15 | |
- Chris | |
12-17-2006, 08:38 PM | #16 |
Thanks for the info. I'll keep you post when I get it going
