04-15-2015, 07:08 AM | #1 |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
| Connecting BEC to ESC terminal With Caps
So I have a cheap Hobbyking ESC. 120amp For our discussion this pic will do. The terminals that the wires feed to also have pos and neg wires that feed to capacitors. I soldered my bec from the same terminals. Its direct power from the battery, but my bec died mid run. It had been abused for over a year and was working flawlessly until wired this way. No smoke or anything, just lost all power mid run. I run my bec into my HV receiver and remove the ESC internal bec wire. My thoughts are that somehow the caps allowed some current discharge to flow into my bec. But the bec, which a castle unit BTW, is designed to pull current from the terminal. Regardless, someone perhaps has more intelligence on the matter and can way in. Bec gives nothing but a green light when connected to the PC. |
04-15-2015, 07:22 AM | #2 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: Connecting BEC to ESC terminal With Caps
So what is the question here or issue? That when plugged into castle link it won't link up? Plug battery in..... Castle link is trying to feed the esc.
04-15-2015, 07:27 AM | #3 | |
| Re: Connecting BEC to ESC terminal With Caps Quote:
Bec = dead... Why? Because of the caps feeding too much current into the bec? | |
04-15-2015, 08:02 AM | #4 |
I doubt it has anything to do with the ESC cap, the Castle BEC can take more input voltage than the ESC and it will only draw as much current as the servo and receiver require.
04-15-2015, 08:50 AM | #5 |
Rock Crawler Join Date: Jul 2011 Location: USA
I wire mine the same way with no issue, and I use alot of the hobbyking xcar esc's. You never know with electronics, sometimes its just its time to give up the ghost. Plus you said you got over a year of abuse out of it. |
04-15-2015, 08:58 AM | #6 |
Has nothing to do with it.
04-15-2015, 08:59 AM | #7 |
Thanks guys. I didn't think so, a year of water and mud, I expected it to die. I just didn't want to replicate the issue by wiring a new one similarly.
Connecting BEC to ESC terminal With Caps - Similar Threads | ||||
Esc not connecting to controller | rccrawler6911 | Newbie General | 5 | 06-06-2012 03:22 PM |
Connecting battery and motor to esc | hansmoolman | Newbie General | 24 | 09-15-2011 04:16 AM |
Connecting the Goat 3S BEC to a Spektrum Receiver. | neo | Newbie General | 3 | 03-28-2010 12:19 AM |
Connecting CC BEC to EVX on E-Maxx | JamboreeTJ | Electronics | 11 | 01-28-2008 06:37 AM |
