12-18-2006, 08:35 PM | #1 |
Rock Crawler Join Date: Dec 2005 Location: Borderland Tejas
| SR problem
I just got done wiring everything up and the lathe motor won't turn. The front and rear servo turn fine, but when pulling the throttle, nothing happens. I put a servo in the motor spot on the reciever and it worked, so the rciever is ok. I'm pretty sure I programmed it correctly. When I push the throttle forward the esc light turns green and when I push the throttle to reverse, it blinks green. All connections have been checked and are tight. I'm going to go pull my TR2 off of my clod and see what it does. I just got this SR on ebay, hope its not crapped out :-( Any other ideas??? |
12-18-2006, 08:46 PM | #2 |
Everything works with the TR2. Is there something special I have to do with the SR? It is plugged into the reciever that same way as the TR2 was( white/red/black). The only difference is that the bare prongs on the SR connector are on the opposite side as the ones on the TR2 connector, but the wires are in the same order. That shouldn't make a difference should it? BTW, I'm using a TQ3 reciever. |
12-18-2006, 08:58 PM | #3 |
Pebble Pounder Join Date: Nov 2006 Location: Tennessee
Did you do the "one touch setup"? Did you try a different motor?
12-18-2006, 09:18 PM | #4 |
Get this, the deans plug connecting the SR to the motor was at fault. If the deans plug was pushed in all the way, it wasn't completing the circuit. But if I pull the plug apart just a hair, we're in business I was really getting worried for a second. |
