12-18-2006, 11:28 PM | #1 |
I joined the Band! Join Date: Dec 2006 Location: RENO
| 55t Integy Or 2.2 Reduction
SO WHY ARE MOST OF YOU RUNNING THE 55T OR 65T INTEGY MOTORS VERSUS RUNNING THE RC4WD 2.2 GEAR REDUCTIONS WITH SILVER CAN 540'S. LOOKING AT TORQUE #'S POSTED BY EGRESSor have some torque numbers pullmaster 12t 6.5oz/in@10Amps pullmaster 10t 4.8oz/in@10A modified MM 5.5oz/in@10A 5pole 15T 540 5.4oz/in@10A lathe 55T 4.9oz/in@10A RS540RH 5.0oz/in@6A the Mabuchi will not suck more amps Johnson540 27t 4.8oz/in@10A THE 540 PULLS 5.0 oz OF TORQUE AT 6 AMPS, WITH THE 2.2 THAT WOULD BE DOUBLED TO 10.2 oz OF TORQUE AT LESS THAN 6 AMPS. ALSO LOOKING AT THE AMP DRAW #'S BELOW RELATED TO RPM, IT WOULD SEEM THAT THE AMP DRAW WOULD ONLY BE SLIGHTLY HIGHER. OVERALL IT SEEMS THEY WOULD HAVE MORE TORQUE, LONGER RUN TIMES, AND MORE TOP END FOR CRAWLING THAN THE 55T INTEGYS. WHAT AM I MISSING? Jam1sstang POSTED RPM #'S FROM A DYNO. Thought I'd post some info from DYNO testing some motors. All DYNO information is an average of (4) 20 second runs at 7.2 Volts. DYNO used was an INTEGY INDI DYNO V2. NEW INTEGY 45T single Lathe motor -- 9325 Rpm's and .66 Amps NEW INTEGY 55T single Lathe motor -- 8450 Rpm's and .62 Amps NEW INTEGY 65T single Lathe motor -- 6400 Rpm's and .43 Amps Used TRAXXAS Stinger 20t single -- 18500 Rpm's and 1.94 Amps Used TITAN 550 -- 13400 Rpm's and 1.68 Amps |
12-18-2006, 11:46 PM | #2 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
you would be suprised at the difference in run time you get out of such a small about of amp. difference. I had a johnson silver can on a gd600 and I got about 40 minutes of run time on a subC 3300 pack. I switched to a 65t lathe and I get arround an hour and 20 min. I know that the amps seem small but when you convert them to milliamps the #'s increase alot and milliamps are what the batteries are rated at. just like a 3600 mah battery last quite a bit longer than a 3300 mah pack. the #'s aren't that much different but the results are very noticable.
12-19-2006, 09:31 AM | #3 |
Overall It Seems They Would Have More Torque, Longer Run Times, And More Top End For Crawling Than The 55t Integys. What Am I Missing? With The Gear Reductions It Would Take 2.2x Less Energy To Get Things Moving Though. |
12-19-2006, 09:51 AM | #4 |
I wanna be Dave Join Date: Mar 2006 Location: One Legend.
Cost, size and weight.
12-19-2006, 10:18 AM | #5 |
You are also missing rpm numbers.
12-19-2006, 02:05 PM | #6 |
Also lower case letters.
12-19-2006, 03:51 PM | #7 |
Pebble Pounder Join Date: Oct 2006 Location: Westbrook Park,Pa.
you realy get an hour runtime from 55 turns....I should have switched to electric sooner.
12-19-2006, 05:15 PM | #8 | |
12-19-2006, 05:29 PM | #9 | |
I was getting ready to say the same thing. As far as the motors though.....you could just get a brushless motor and CRUSH either one of those motors | |
12-19-2006, 09:21 PM | #10 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
plus and this is huge... well waht i noticed is you have one speed with the gear reduction system slow, i think there is defintiley more variety in speed incase you need to hop up or down somethin. know what im saying? |
12-19-2006, 10:23 PM | #11 | |
true that brother true that! | |
