12-19-2006, 09:57 AM | #1 |
Pebble Pounder Join Date: Jun 2006 Location: Rapid City
| RX and Servo voltage
I have a 4WS setup and I am looking for more power for my servos with out spending a butt load of $ on new servos. Servos have two voltages listed for torque output. The max voltage is 6.0 using a RX pack. I'm sure with just one servo that most of the voltage is going to the single servo but with a 4WS setup is the voltage split between the two and can I get more power by running more volts? Lets say a 9v battery, lighter and smaller than 4 "AA" but a whole volt and a half more to each servo.
12-19-2006, 10:03 AM | #2 |
Rock Crawler Join Date: May 2006 Location: United Kingdom,Scarborough
The more voltage you get to your truck more wheel speed you may get And more torque you get from servo[s] The voltage is devide between the servo[s] and motor[s] |
12-19-2006, 10:25 AM | #3 |
Not if you wire them parallel. RX's split the current, not the voltage.
12-19-2006, 10:47 AM | #4 | |
I'm using a TQ3 with a "Y" connecter for the steering servos and my third channel runs a micro servo for a rear dig. When I disconnect my rear servo the front one does turn alot better. | |
12-19-2006, 11:10 AM | #5 | |
Pebble Pounder Join Date: Sep 2006 Location: SW Charlotte
parallel rx to 2 servos = full voltage & half mah to each servo series rx to 2 servos = half voltage & full mah to each servo | |
