12-19-2006, 07:51 PM | #1 |
Rock Stacker Join Date: Nov 2006 Location: knoxville
| loss of power when in bind???
BTW... I have searched... cant find topic. My crawler stops (no power, esc goes dead) when it gets in a bind. If I lift it up, it comes back to life. What gives? Thanks for the help. |
12-19-2006, 08:03 PM | #2 |
Pebble Pounder Join Date: Nov 2006 Location: Tennessee
Please post more info of what esc motor truck and so forth.
12-19-2006, 08:07 PM | #3 |
Quarry Creeper Join Date: Feb 2005 Location: Lake Tapps, Washington
you are over amping the BEC. I B.. |
12-19-2006, 08:07 PM | #4 |
Im running: Novak Super Duty 7 sub c 3600 mah batts 55 lathes 7 & 8 tooth pinions Moab XL's Clod axles |
12-19-2006, 08:12 PM | #5 |
I.B., please explain to me what over amping the bec means and how can I fix this? Thanks, Steve |
12-19-2006, 08:21 PM | #6 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
yeah i could use help with that too. i have an LRP f1 pro reverse used it all year and now all of a sudden its haveing problems just like above. on inclines it just shuts down until i pick it up.
12-19-2006, 08:22 PM | #7 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
Sounds like you're just stalling the motors when in a bind. If you ran brushless you'd be breaking parts. Also...how old are the motors? Are they in good condition? |
12-19-2006, 08:22 PM | #8 |
Its when to many amps are put to the bec, it will stall everything. are you running the big power cap that the super duty needs?? if not that might be the problem. I B.. |
12-19-2006, 08:32 PM | #9 |
when this (loss of power) happens, the esc shuts down, no steer, no motors, no rear steer... nothing. Lift it up out of the bind and it starts working again. I B.. Sorry, I'm green. What is the "big power cap"? |
12-19-2006, 08:38 PM | #10 |
Sounds like the servos are stressing the BEC, and it is shutting down.
12-19-2006, 08:45 PM | #11 |
My brothers Twin would do simular. He wouldn't have to pick it up though,he could just give it a nudge and it'd be off again. He's running 8 GP3300 cells,Super Rooster,stock 27 turn motor and 2 Airtronics 359's. We first thought it was the new motor needed a break in. Ran it under water for a bit....nope,still done it. Tried switching channels......nope,still there. Tried 4 different battery packs.....nope,tried switching recievers.....nope. We added a reciever pack for the servo's and pulled the red wire....walla,runs perfect and has ever since.
12-19-2006, 08:55 PM | #12 | |
This link should help. The SD has to have one.. I B.. | |
12-19-2006, 09:07 PM | #13 |
yes, it does have the power cap. yes, you can bump it and it will come back to life. the reason I bought the $150 Super Duty is that it was suppose to run the 5645's with its 6 volt 3amps with out the need for a rcvr pack. Was this wrong? |
12-19-2006, 09:08 PM | #14 |
well now that his is solved whats with mine? doesnt have to bind just after runnin for a while it doesnt want to go on anything that isnt flat, doesnt have to bind just not a flat surface, it never did this before i ran it for 6 months prior, im thinkin its just old and tired. the motor is new on mine a integy 55. so whats the deal? |
12-19-2006, 09:14 PM | #15 |
do I need a rcvr pack? Will this fix my problem of loss of power under a bind?
12-19-2006, 09:24 PM | #16 | ||
Bind or no bind,sounds like they are doing the same thing to me. Same problem,same solution......swingy swingy duh Since yours WAS working,don't you think maybe the BEC went out in the ESC???? It's not like your the only one thats had issues with the LRP ESC. | ||
12-19-2006, 09:37 PM | #17 | |
what will help also, I do this on my 2.2 reg rooster and a 94358 it stalls bad, so I use the Novak super power cap and plug it into the batt port on the rcvr. It helps alot. I B.. | |
12-19-2006, 10:07 PM | #18 | |
Thats what I thought with my brothers as well. Brand new Super Rooster shoulda powered the servo's fine......nope. Sometimes things are faulty We probly could send our SR back and let them fix the BEC. Running a reciever pack is easier for us,so thats what we did. | |
12-19-2006, 10:09 PM | #19 |
He is also running 7 cells, kiss the 3 amps BEC goodbye. All ESC's that I know of are rated at 7.2 volts input, not 6 freshly charged cells even. |
12-19-2006, 10:12 PM | #20 | |
I wanna be Dave Join Date: Mar 2006 Location: One Legend.
