12-19-2006, 11:53 PM | #1 |
Quarry Creeper Join Date: Aug 2004 Location: North Las Vegas
| Wiring a rx pack for dual servos.
I'm running 2 towerpro's on my Clod and would like to add a rx pack. Other than mounting them to the front axle, how or what is the best way to tie the batts into the rx? Should I just run a wire from the mounted packs to the rx into the bec slot? I want my extra cells for both sets of servos so keep that in mind. Am I to understand that both servo's will get enough power with a single pack hooked up to the bec or will I have to install 2 seperate packs for both? |
12-20-2006, 03:19 AM | #2 |
Newbie Join Date: Mar 2004 Location: cromwell , ct .
usually 1 pack should do it . just put a switch in line as well , since there wont be any on/off without it( servo's will constantly have power ) .
12-20-2006, 02:11 PM | #3 |
Rock Stacker Join Date: Jul 2006 Location: 2" behind my eyes
Someone chime in if i'm wrong but i think you also have to disconnect the red wire where the esc plugs into the rx. if not, you'll be sending alot of power to the rx and possibly burn it up. Atleast that's how i have both of my crawlers wired. my clod has 2 hitec 5995's and works great.
12-20-2006, 02:17 PM | #4 |
RCC Addict Join Date: Jan 2005 Location: Germany north
i have tested some MG995 servos they want no more than 2.1 amps loaded and they like 7.2V torque 120Ncm @4.8V 170Ncm @6V and 210Ncm @7.2V |
12-20-2006, 02:56 PM | #5 |
So it will be like this, 1 batt pack with 2 sets of reds and blacks coming out and attaching straight into the red and black of the servo's before they reach the rx or should I just plug the 6 volt pack into the rx and let it sort out the extra power? |
12-23-2006, 06:34 PM | #6 |
Rock Stacker Join Date: Dec 2006 Location: Jacksonville
I would like to know also ,I am running a novak super duty with twin 55t's and a 5955 up front and a 645 in the rear.I run two 3000 bats hooked to the esc.So I can just hook up another rx pack to the esc where the extra unused plug goes?I asume this will add more power to the whole mix instead of the two batteries I have supplying all the juice to motors,esc and servos.somebody explain this [please,pics would be great or a simple drawing if you have.Thanks
12-23-2006, 07:24 PM | #7 | |
12-23-2006, 07:51 PM | #8 |
thanks I will get on that tomorrow
