12-27-2006, 07:42 AM | #1 |
Pebble Pounder Join Date: Nov 2006 Location: Fernley,NV
| servo ??
i have jr racing DZ8550 servos in my stick. the front one works as long as theres no load on it, you can stop the shaft from moving with your finger. my question is can i run different servos?? i would like to replace the front one with a hitec 5955 and the rear later. i'm using a TQ3 radio and a rebel 2, thanks dave!
12-27-2006, 07:43 AM | #2 |
Pebble Pounder Join Date: Oct 2006 Location: under a rock
Don't see why not,should work fine
12-27-2006, 08:11 AM | #3 |
I wanna be Dave Join Date: Mar 2006 Location: One Legend.
Before you replace that servo, try a receiver pack or wire in a voltage regulator! Those servos want a little more amperage than the BEC provides, especially when using more than 6 cells. Also, the servo horns that are on there have a plastic insert inside a metal horn, make sure the insert isn't stripped! They worked fine for me for 2 comps and a bunch of practice, and I was kinda surprised th BEC would push them. Sorry you are having issues now! If they are hurting, it may be because you went to a radio without endpoint adjustments. Digital servos don't like that at all! You'll hurt the 5955s quick without endpoint adjustments too. Last edited by Unholy; 12-27-2006 at 08:19 AM. |
12-27-2006, 10:46 AM | #4 | |
the plastic insert was the first thing i checked its in good shape. i thought a 90% servo did'nt need end point adjustments?? and no worries,i'm very happy with it and have used it alot its just wear and tear,that and i'm a little harder on things than most ppl,i dont think theres a part on my 1:1 i have'nt broken !! Last edited by throttleboy; 12-27-2006 at 12:08 PM. | |
12-27-2006, 01:09 PM | #5 | |
12-27-2006, 03:52 PM | #6 | |
12-27-2006, 04:14 PM | #7 |
Yeah, playing with steering link length and servo arm length can put you in the right steering range. You can drill and tap the curent arm at one of the other holes to shorten its throw.
12-27-2006, 05:08 PM | #8 | |
