12-27-2006, 11:29 AM | #1 |
Rock Crawler Join Date: Jan 2006 Location: Derbyshire UK
| Rebel 2, Brake?
Is it possible to programme a rebel 2 so that when you let go of the throttle the brake comes on? When I let go of the throttle going down hill , the truck runs away , the only way to hold it on a downhill is to select reverse,(fitted to a clod / stick) Is this how it should be? I have a mtronics ESC on my tlt and as soon as I let go of the throttle the brake comes on. this makes it very easy to control when going down hill. How do I set the braking feature up on this esc? I hope someone can help, JOHN. |
01-01-2007, 08:32 AM | #2 |
Quarry Creeper Join Date: Dec 2006 Location: Acworth
The easiest way I can think of is to set your throttle trim toward brake so that you offset where neutral is, but I would set your reverse delay to max.
