12-27-2006, 11:16 PM | #1 |
Quarry Creeper Join Date: Jan 2006 Location: Winston-Salem
| TQ3 - 3rd channel?
My nephew wants me to mod a 1/4 scale servo to use as a winch and I had a quick question. Last night I hooked the servo up to the 3rd chan. on TQ3 on his truck to test it. It works like it should for 4WS. Switch up-servo turns one direc., switch down-servo turns other direc. switch centered- servo centers. When I hooked my servo up to it that has been modded for a winch (pot glued in center position). With switch up-servo(winch) turns one direc. With switch centered- servo turns same direc. With switch down- servo turns other direc. In other words, The servo will turn both ways but does not have an off position. I thought that maybe switch centered would be off. I realize that it won't work like that but is there a way to get it to? On my JR 3 channel Tx. The servo will only turn one direc. Because my 3rd chan. is just like an on-off switch. It doesn't reverse the polarity, which is fine with me. I just wanted to know if I can get it to work with his TQ3 and have in-off-out feature? Thanks.
12-27-2006, 11:18 PM | #2 |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
Sounds like you don't actually have the pot in the centered position.
12-27-2006, 11:21 PM | #3 |
I hope this can help you: winch with 3way switch probs |
12-27-2006, 11:34 PM | #4 |
My nephew said it may not be centered either. I let the CA dry before reassembling servo. It was still centered when I put it back together. The motor wasn't turning either direc. when I checked it.I may have to dig a little deeper to find out what's up. Maybe put an external pot on it to make sure it's staying in the center position. Thanks Jason and Gula.
12-27-2006, 11:40 PM | #5 |
Have you tried adjusting the trim on the third channel to center it?
12-27-2006, 11:43 PM | #6 |
No I haven't. Worth a try though.
