10-13-2015, 06:49 PM | #1 |
Newbie Join Date: Sep 2015
| At my wits end......help!
Alright I have burned up two servos ever sense I installed my new CC BEC, I run ae-2, AR-3, 55t motor, and a 6cell venom, the servos that burned tactic TSx45, then a 220oz traxxas. What in the world??? Could it be the BEC?? Sent from my SM-G360T1 using Tapatalk |
10-13-2015, 07:16 PM | #2 |
Quarry Creeper Join Date: Aug 2014 Location: sacramento
| Re: At my wits end......help!
What voltage is your bec set too
10-13-2015, 07:17 PM | #3 |
5.5, the first servo then was told 5.5v wasn't enough for the 220oz and to turn it up to 6.5v for the second one Sent from my SM-G360T1 using Tapatalk |
10-13-2015, 07:18 PM | #4 |
Or less than mediocre servos…
10-13-2015, 07:19 PM | #5 |
Hun??? Sent from my SM-G360T1 using Tapatalk |
10-13-2015, 07:29 PM | #6 |
Hun????
10-13-2015, 07:32 PM | #7 |
I hey what u are saying but the odds of burning two out after installing a BEC? The BEC is the only this that has changed... Sent from my SM-G360T1 using Tapatalk |
10-13-2015, 07:35 PM | #8 |
What type of rig are you running the servo on and about how much does it weight Might be time to step up to a better servo 300+ oz, hitec, savox, ect.. |
10-13-2015, 07:35 PM | #9 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
You're not running both the separate bec and the one from the esc at the same time are you?
10-13-2015, 07:35 PM | #10 |
Ax10 full aluminum other then that axals Maybe 4-5lbs Sent from my SM-G360T1 using Tapatalk Last edited by THX_138; 12-28-2015 at 09:14 PM. Reason: Merge, posting seconds apart |
10-13-2015, 07:36 PM | #11 |
I'd guess you overworked those servos cause they're not all that strong/great, and fried them. So now you're ~$50 in the hole, and need another. This time, get a good one. Of course you don't have to take my advice but I've been there before. As have many others.
10-13-2015, 07:38 PM | #12 |
The last one burned up in about 8-10 min after installing it, and it was being run in my living room.....that's way I said I'm at my wits end Sent from my SM-G360T1 using Tapatalk |
10-13-2015, 07:44 PM | #13 |
Make sure the steering stuff isn't all bound up. If you can check the output voltage of the BEC with a voltmeter. It can only be all of a few things. |
10-13-2015, 07:46 PM | #14 |
Ok I'll get one, thanks. Sent from my SM-G360T1 using Tapatalk |
10-13-2015, 10:07 PM | #15 |
RCC Addict Join Date: Nov 2014 Location: Nowhere
I've had a stock Tactic die on me, along with a Traxxas 2075 out of the blue. Also, make sure your end points are set correctly and the servo isn't binding itself. That's 100% guaranteed to prematurely kill your servo if you find it trying to still turn while your steering is maxed out.
10-14-2015, 06:25 AM | #16 |
Yeah, it was trying to continue turning even after I let go of my controler, it did it twice and the last time it fried out Sent from my SM-G360T1 using Tapatalk |
10-14-2015, 11:15 AM | #17 |
Depending on what radio you have then, if its the stock Axial radio, you have to use a dial to turn the steering dual rate down.
At my wits end......help! - Similar Threads | ||||
2012 End of Days, 4X to the end of the world, Jan Comp. | willipmartinni | Utah | 12 | 01-19-2012 08:09 PM |
Exact length of links from end of ball end to other? | ccampb04 | Tamiya TLT Crawlers | 5 | 04-11-2005 11:01 PM |
