12-30-2006, 11:36 AM | #1 |
RCC Addict Join Date: Dec 2004 Location: HELL.....
| novak XRS or other small esc's?
i am looking for a small esc to run a lathe motor in my high lift. i need the real estate, so its gotta be small. is the xrs any good? or are there other small esc's that are cheap but good?
12-30-2006, 11:44 AM | #2 |
Rock Crawler Join Date: Jan 2006 Location: Connecticut
Im running an XRS and every now and then when im climbing and my tires become "stuck" on rocks it stops working and just makes noise. Once i pick it up or move the truck it works like normal. I belive it is because of the BEC on the unit. Other than that it works great!
12-30-2006, 12:08 PM | #3 |
Pebble Pounder Join Date: Sep 2005 Location: minocqua
the xrs had a dubble pump reverse, where when you put it into reverse it applys brake then reverse once it is stoped, vs others where tghere is no pause, which is better for crawling.
12-30-2006, 12:56 PM | #4 |
its going in my high lift, which isnt critical in crawling. its a scaler not a comp rig.
12-30-2006, 01:09 PM | #5 |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
i actually like the double pump action of my XR on my clod. you can mash the brakes for decents and it'll help you control your vehicle more. if you are starting to tip, you simply "double pump" the throttle in reverse and away she flys backwards!!!
12-30-2006, 01:21 PM | #6 | |
The XRS is nice, I don't really have any complaints. There's means around a weak BEC so that shouldn't deter you from a purchase of any speed control. But as is, it works good with one servo, even an Airtronics 200 oz Rock Crusher. Or two lesser demanding servo's, like the two in the Spektrum DX3 package, and in my Hi Lift. | |
12-30-2006, 03:48 PM | #7 |
ya i didnt think about that. whats the BE current on the XRS? i am running a 6ch in my high lift, with 4 micro servos, 1 stock and 1 high torque |
12-30-2006, 04:11 PM | #8 |
Rock Crawler Join Date: Feb 2006 Location: Easthampton
what about a Moped esc?
12-30-2006, 04:13 PM | #9 |
Newbie Join Date: Aug 2006 Location: HELL
I like the associated quantum or the new novak rooster.
12-30-2006, 06:13 PM | #10 |
rooster is too big. how big is the moped? |
12-30-2006, 06:20 PM | #11 | |
Quarry Creeper Join Date: Aug 2004 Location: Southwestern PA
12-30-2006, 06:23 PM | #12 |
Rock Crawler Join Date: Apr 2006 Location: Salem, Orcrc
id have to say moped also, its pretty small 1.5"x1.5" doesnt get hot, doesnt have double pump, doesnt do any wierd stalling, easily handles 2 lathe motors. it has a decent BEC and should be able to handle the two servos on the highlift.
12-30-2006, 06:25 PM | #13 |
Quarry Creeper Join Date: Dec 2006 Location: Dirty Jerzee
the moped would be your best bet |
12-30-2006, 06:57 PM | #14 |
Rock Crawler Join Date: Sep 2006 Location: Esco.
I have been running the XRS with no probs for awhile now. Best way to go if you are real estate challenged. |
