01-03-2007, 11:04 AM | #1 |
| Laptop Ni-MH cells?
I have a couple laptop batteries here...Toshiba 7.2 volt 4000 mah Ni-MH...(thought they were Li-Ion, but they're not) who's used these, what charger, good, bad, or? EDIT: Haven't torn this open yet, but they look like they are about AA size cells, but a bit longer. Last edited by Natedog; 01-03-2007 at 11:31 AM. |
01-03-2007, 11:08 AM | #2 |
Rock Crawler Join Date: Apr 2006 Location: Salem, Orcrc
im not sure anyone has used laptop cells but they seem like a good idea, once you get them in a pack youd need a charger that can handle 4000mah. contact christhebatteryman, hey would probably have some info.
01-03-2007, 12:25 PM | #3 |
I think my chargers will already handle this...have to double check. Got the pack apart and it is made up of 6 Toshiba Nimh cells, size 4/3A. They are 2 5/8" long X almost 11/16" diameter. The pack has a thermal probe for charging in the laptop so it doesn't overcharge/overheat.
01-03-2007, 12:51 PM | #4 |
Rock Stacker Join Date: Jan 2005 Location: Fort Collins
What charger do you have? Before you build them up for your rig I'd try discharging them to see if they will handle the load.
01-03-2007, 02:22 PM | #5 |
This is the charger that I use most of the time, works great and good price, just no li-po capability: Piranha Digital Peak Charger LCD Screen Angled for easy viewing, the Digital Peak Charger's custom LCD screen shows battery voltage, peak detection mV, charge time, current, capacity and more. Exceptional peak charging value — with SIX programmable features! * Two-line, 16-character LCD shows battery voltage, peak detection mV, charge time, current and capacity — as well as errors for improper input voltage, poor battery connections, and reverse output polarity. * Memory stores pre-set charge parameters for up to 10 batteries. * Automatic charge mode takes effect and charges batteries safely if specific settings are not selected. * Compact size (5" x 3.4" x 5.5") and AC/DC input options allow convenient use at home or the track. * Solid-state reverse polarity and short circuit protection included on input and output. 5-year warranty Tailor operation to your specific battery types with these programmable features: Feature Programmable Range Battery Type NiCd, NiMH - 1-8 cells Charge Current 0.1-5.0A Battery Capacity 50-5000mAh Peak Sensitivity 3-20mV Trickle Current 0, 100, 200mA Sounds 5 Stock Number: DTXP4005 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Works great and great price. |
01-03-2007, 04:43 PM | #6 |
It will charge them fine. Weather or not they will handle the amp draw of your setup is another question.
01-03-2007, 04:49 PM | #7 |
They will charge as any other nimh. As newracer said, will they handle your motor? I really doubt it. They were built for capacity and not discharge rate since it is in a laptop. You might squeeze 5 amps out of them, I would be very suprised to find more than a 10 amp discharge. What motor are you gonna run?
01-03-2007, 08:25 PM | #8 |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
I would HIGHLY doubt that those cells are anything close to high-drain. Applications like that call for low-drain cells. This would probably result in very short runtimes, battery life, and bad overall performance.
01-03-2007, 10:09 PM | #9 |
Currently I'm using a Tamiya sport tuned (black can) motor, my Integy 45T lathe motor just showed up today. What's the best way to test their discharge? Don't really want to solder up a real nice pack if they're going to suck. |
01-03-2007, 11:38 PM | #10 |
Well there isn't any real easy way to test cells like that. Your best bet is to attach leads and see if they hold up. And another fyi.... theres no way 4000mah will fit into a AA cell. Click here for dimensions of many cells. That will help you better judge their size. http://www.cheapbatterypacks.com/mai...gid=loosecells |
01-03-2007, 11:47 PM | #11 | |
01-04-2007, 08:12 AM | #12 |
I would test the cells with a motor and prop, with a wattmeter hooked in between. Throttle up and it will show very quickly how much discharge they will take. Super easy.
01-04-2007, 08:58 AM | #13 |
Newbie Join Date: Dec 2006 Location: Stationed in Germany
using Lipo cells can be very dangerous if not used properly... I would some research before ever considering this!
01-04-2007, 09:02 AM | #14 |
I wanna be Dave Join Date: Sep 2005 Location: R.I.P. Chip
The cells he's talking are nimh!
01-04-2007, 09:07 AM | #15 |
sorry about that... I skimmed... checked my laptop.. then proceded to put my foot in my mouth! But if anyone is interested here are some links for LIPO Info: http://www.pfmdistribution.com/files...Guidelines.pdf http://www.dynamoelectrics.com/LiPo%20Essay.aspx http://mysite.verizon.net/kevinkel/index.html I guess I just got excited about knowing something :-( Maybe I can pull my foot out of my mouth over the next few days... |
01-04-2007, 11:34 AM | #16 |
Thanks Johnrobbholmes, have to look into a watt meter and appropriate motor and prop. Minirctalk, laptop batteries can be Li-Ion, Ni-MH, or Li-Po...depending on the laptop. Li-pos are ok if you handle them properly, but the require alot more caution than Ni-Cd and Nimh. |
01-04-2007, 01:56 PM | #17 | |
Newbie Join Date: Jun 2005 Location: clinton twp
01-04-2007, 02:18 PM | #18 |
Or buy a discharger or a charger that discharges.
