01-04-2007, 06:19 PM | #1 |
Rock Stacker Join Date: Jul 2005 Location: Davison
| Traxxas XL-5 esc
Anyone have any experience with this esc? Thoughts or opinions please. I just picked up a new one for next to nothing and plan on using it in my TLT based crawler. Z-Rider |
01-04-2007, 09:21 PM | #2 |
It will work fine, but it doesn't have the low speed crawl control. It really isn't made for slow crawling, but if you are not too worried about fine slow control it will work otherwise.
01-05-2007, 06:11 AM | #3 |
Thanks for the info!
01-05-2007, 08:39 AM | #4 |
I use it with my 2.2 Clod.....It's better then the Moped. It has real good low speed control... It will be fine. I love it.
01-05-2007, 03:43 PM | #5 |
Sorry I was thinking of the XL 1.
01-06-2007, 05:42 AM | #6 |
Great! Thanks guys.
01-09-2007, 10:18 AM | #7 |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
does anyone know how to set this up? Just picked one up and traxxas.com produces nada and i yahoo search keeps pointing to traxxas.com's community pages where people post up thier stock stampede xl-5 pics... no help whatsoever... just wanna know how to set it up. (it has a setup button and dont know what it does) thanks guys
01-09-2007, 10:56 AM | #8 |
heres what i found so far: The Traxxas XL-5 Electronic Speed Control provides smooth and consistent throttle control for the enthusiast who wants to extract the most from their mild modified and stock motors. The XL-5 features EZ-Set™ push-button setup for easy operation, four throttle profiles, 4-8 cell compatibility, and thermal shutdown production. High frequency operation combined with ultra low resistance make the XL-5 an efficient and ultra-smooth fully proportional speed control. The XL-5 is backed by the Traxxas Lifetime Electronics Warranty. Patent-Pending Training Mode™ An exclusive feature that places the XL-5 ahead of the pack is the patent pending Training Mode. This feature reduces the overall power output of the XL-5 by 50% making it easier for new drivers to control their model. When they’re ready, simply change profiles to unleash full-throttle action. Only Traxxas has it! New XL-5 ESC Features 15-turn motor limit for 540 size motors 12-turn motor limit for 550 size motors Fully-proportional forward, reverse, and braking control Programmable with four drive profiles: Sport Mode – Fwd / Brake / Rev Race Mode – Fwd / Brake Training Mode – 50% Fwd / Brake / 50% Rev 100% Fwd, 25% Rev, No Brakes EZ-Set™ push-button setup Multi-color LED Thermal shutdown protection Efficient, low-loss MOSFET design High-capacity heat sink Smooth, high-frequency operation XL-5 SPECIFICATIONS Input voltage: 4-8 Cells (4.8 to 9.6 Volts DC) Case Size: 1.23"W x 2.18"D x 0.61" H Weight: 2.44 Ounce Motor Limit: 15-turns* (540 Size) 12-turns* (550 Size) On Resistance Forward: 0.007 Ohms On Resistance Reverse: 0.014 Ohms Peak Current - Forward: 100A Peak Current - Reverse: 60A Braking Current: 60A Continuous Current: 14A BEC Voltage: 6.0 VDC BEC Current: 1A Power Wire: 14 Gauge / 5" Input Harness Wire: 26 Gauge / 9" Transistor Type: MOSFET PWM Frequency: 1600 Hz Thermal Protection: Thermal shutdown Profile selection: Profile 1: Sport Mode: 100% fwd, 100% brakes, 100% rev Profile 2: Race Mode: 100% fwd, 100% brakes, no rev. Profile 3: Patent Pending Training Mode™: 50% fwd, 100% brakes, 50% rev. Profile 4: 100% fwd, 25% rev, no brakes Single-button setup: Yes, Traxxas EZ-Set™ no manual yet..... www.traxxas.com sucks when you are trying to find something. |
01-09-2007, 11:18 AM | #9 |
OK.. heres all the info you need to know about the XL-5 and setting it up Page 16 is esc setup XL-5 electronic speed controls are factory set and should not require any adjustments. These instructions are provided for your reference. Precautions • Motor Limit: The XL-5 has a 15-turn modified motor limit for 540 size motors and a 12-turn modified motor limit for 550 size motors when the motor is properly geared. If the motor or speed control is overheating, try a smaller pinion gear. Do not attempt to use a more powerful motor (fewer turns) than the above mentioned motor limits or you could experience frequent thermal shutdown. • Insulate the Wires: Always insulate exposed wiring with heat shrink tubing to prevent short circuits. • Water and Electronics Do Not Mix: Do not operate the model in or around water. Never allow water, moisture, or other foreign materials to get inside the speed control. • Disconnect the Batteries: Always disconnect the battery pack from the speed control when not in use. • Transmitter on First: Switch on your transmitter first before switching on the speed control to prevent runaways and erratic performance. • Don’t Get Burned: The transistor tabs and the heat sinks can get extremely hot, so be careful not to touch them until they cool. Supply adequate airflow for cooling. • Always Use Heat Sinks: Three heat sinks are factory-installed on the speed control and must be used for maximum cooling and performance. • 4 to 8-Cells Only: The XL-5 can only accept a maximum input voltage of 9.6 volts. Always adhere to the minimum and maximum limitations of the XL-5 as stated in the specifications table. • Use Stock Connectors: If you decide to change the battery or motor connectors, only change one battery or motor connector at a time. This will prevent accidentally mis-wiring the speed control. If the XL-5 is not wired exactly as shown in the diagram, it can be damaged! Please note that modified speed controls can be subject to a rewiring fee when returned for service. • Use Neutrally Timed Motors: For reverse use, the motors must have 0° timing. Modified motors (with adjustable end bells) timed to 0° or Johnson/ Mabuchi (closed end bell) motors are recommended. Using motors with other than 0° timing will draw excess current in reverse, and can result in the speed control overheating and premature motor wear. • No Reverse Voltage: The speed control is not protected against reverse polarity voltage. When changing the battery and/or motor, be sure to install the same type of connectors to avoid reverse polarity damage to the speed control. Removing the battery connectors on the speed control or using the same-gender connectors on the speed control will void the product’s warranty. • Motor Capacitors Required: Ceramic capacitors should be properly installed on every motor to prevent radio interference. • Do Not Let the Transistor Tabs Touch: Never allow the three separate transistor banks to touch each other or any exposed metal. This will create a short circuit and damage the speed control. • No Schottky Diodes: External schottky diodes are not compatible with reversing speed controls. Using a schottky diode with the XL-5 will damage the ESC and void the 30-day warranty Transmitter Adjustments for the XL-5 ESC Before attempting to program your XL-5 ESC, it is important to make sure that your transmitter is properly adjusted (set back to the factory defaults). Otherwise, you may not get the best performance from your speed control. The transmitter should be adjusted as follows: 1. Set the throttle neutral switch to the 50/50 setting. 2. Set the throttle trim to the middle “0” setting. This adjusts the neutral position. 3. Set the Channel 2 servo reversing switch to the left position. 4. Do not change the position of any of the servo reversing switches after programming the XL-5 ESC. XL-5 Setup Programming Read through all of the programming steps before you begin. If you get lost during programming or receive unexpected results, simply unplug the battery, wait a few seconds, plug the battery back in, and start over. The default profile is Profile #1, 100% forward, 100% brakes, 100% reverse. You can change the profile later after setup is complete. 1. Disconnect one of the motor wires between the XL-5 and the motor. This is a precaution to prevent runaway when the speed control is turned on before it is programmed. The motor does not run during the programming sequence. 2. Connect a fully charged battery pack to the XL-5. 3. Turn on the transmitter (with the throttle at neutral). 4. Press and hold the ESC set button (A). The LED will first turn green and then red. Once the LED turns red, immediately release the set button. The red LED will turn off after one and a half seconds. 5. Next, the LED will blink RED ONCE. Pull the throttle trigger to the full throttle position and hold it there (B). 6. After two seconds, the LED will blink RED TWICE. Push the throttle trigger to the full reverse/brake position and hold it there (C). 7. Finally, the LED will turn solid GREEN, indicating the programming sequence is complete. The LED continuously shines green indicating the XL-5 is on and at neutral (D). |
01-09-2007, 11:18 AM | #10 |
Selecting Profile #1 (100% Forward, 100% Brakes, 100% Reverse): 1. With the ESC off and the battery plugged in, turn on the transmitter with the throttle at neutral. 2. Press and hold the set button. The LED will turn green, then change to red and then turn off. Continue holding the set button (A). 3. When the LED blinks red ONCE (B), release the set button (C). 4. The LED will turn solid GREEN (D), indicating the profile programming is complete. Selecting Profile #2 (100% Forward, 100% Brakes, No Reverse): 1. With the ESC off and the battery plugged in, turn on the transmitter with the throttle at neutral. 2. Press and hold the set button. The LED will turn green, then change to red and then turn off. Continue holding the set button (A). 3. When the LED blinks red TWICE (B), release the set button (C). 4. The LED will turn solid GREEN (D), indicating the profile programming is complete. Selecting Profile #3* (50% Forward, 100% Brakes, 50% Reverse): This profile is provided to reduce the power output allowing beginning drivers to better control the model. As driving skills improve, simply change to profile #1 or #2 for full-power operation. 1. With the ESC off and the battery plugged in, turn on the transmitter with the throttle at neutral. 2. Press and hold the set button. The LED will turn green, then change to red and then turn off. Continue holding the set button (A). 3. When the LED blinks red THREE times (B), release the set button (C). 4. The LED will turn solid GREEN (D), indicating the profile programming is complete. |
01-09-2007, 11:58 AM | #11 |
Rock Stacker Join Date: Nov 2005 Location: under the bridge
I've been running xl-5 for three months now have no complaints I use set up "4" I like it alot and yes it has fine control for low speed
01-09-2007, 12:28 PM | #12 |
ive been wondering about the setup 4... fwd and rev... is there a relay.. guess i can just answer that myself once i get her wired up tonight...
01-09-2007, 12:35 PM | #13 |
The reverse is a double tap. So it all depends on oh fast you can hit it.
01-09-2007, 12:36 PM | #14 |
Mines set one profile one.
11-14-2013, 12:22 PM | #15 |
Newbie Join Date: Oct 2013 Location: Eastern
| Re: Traxxas XL-5 esc
Hey guys bumping an old thread, but when I try to program the esc I hold the set button I get a green light, than it turns red when I release the button it stays red. What is this indicating?
11-14-2013, 12:37 PM | #16 |
Rock Crawler Join Date: Jan 2008 Location: Lehigh Valley, Pa
If it stays red, that means your turning off the low voltage cut off. If it stays green, that means its turned on.
11-15-2013, 09:08 AM | #17 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
For those wanting to use this speed control, why, I dont know. You can get a AE-2 for the same price and its much better for scale/rock vehicles.... Here is the link to the manual. Feel free to read up in case you missed all the information posted above..... Traxxas - XL-5 ESC (#3018R) - Downloads | traxxas.com |
