01-05-2007, 02:35 PM | #1 |
Rock Crawler Join Date: May 2006 Location: United Kingdom,Scarborough
| RX pack for Tekin Rebel 2 ?
Hi Can i install a 4.8v rx pack or a 6.0v pack with my Tekin Rebel 2 to boost the power up a bit? This is what i will be running. One Tekin Rebel 2 Electronic Speed Controller 8 cell 1500mAh battery pack TQ3 Radio System with rear steer installed One Hitec 5645mg Metal gear servo for rear steering One Airtronics 94359Z for front steering two 8 tooth pinions 2 55 Lathe Motors Thanks james |
01-05-2007, 02:44 PM | #2 |
Rock Crawler Join Date: Jan 2006 Location: Derbyshire UK
Hi James thats what I am running in my stick (65t motors) and the rebel 2 seems to power the servo,s with no problems. Cheers john.
01-05-2007, 02:52 PM | #3 |
What voltage rx pack are you running? And do you notice a big difference in run times?
01-05-2007, 02:55 PM | #4 |
Sorry Mate ! I,m Running A Rebel2 Without An Rx Pack, It Works Ok!
01-05-2007, 02:57 PM | #5 |
Ok thanks.i have read people say they get about 30mins runtime. Just thought that if i run a Rx pack i will get more power and runtime Thanks james |
01-05-2007, 03:02 PM | #6 |
I don,t know how much difference ti will make to run times. How many packs are you getting for your stick?
01-05-2007, 03:08 PM | #7 |
i will only have the one for now but i will probally make some knuckles packs or buy some more stick chassis packs in the near future Thanks james |
01-05-2007, 03:09 PM | #8 |
Quarry Creeper Join Date: Jul 2005 Location: Oran, MO
I don't think you will get anymore power, maybe a little extra runtime depending on your servos current draw.
01-05-2007, 03:14 PM | #9 | |
Regards james | |
01-05-2007, 04:35 PM | #10 |
Quarry Creeper Join Date: Feb 2006 Location: Tweaking my shaft
I would try a 6 volt Rx pack(or servo regulator) with that set up, just because of the digital servo. I ran a Rebel 2 with a 645 and a 985 with no problems. Now that I am running the 985 and a 5955 digital, the BEC won't like that very much. I am installing a servo regulator as soon as the brown truck shows up. I decided to use a regulator so I wouldn't have to mess with multiple batteries.
01-05-2007, 04:36 PM | #11 |
O'k i will try that Thanks james |
01-05-2007, 04:59 PM | #12 |
Release your anger.. Join Date: Oct 2006 Location: North American Union
try this RX pack http://www2.towerhobbies.com/cgi-bin...&I=LXMEY1&P=ML |
01-05-2007, 05:49 PM | #13 |
Running an 8 cell main pack will reduce the BEC to less than 3 amps. If you use a 6 cell main pack you probably wont need an RX pack. If you are set on running 8 cells, keep the ESC switch in the off position and use a 5 cell RX pack of any cell type.
01-06-2007, 04:16 AM | #14 |
Ok Thanks When i get my stick built i will try it Thanks Again ~james~ |
