Thread: Traxxas audio input voltage
Old 02-17-2016, 01:26 PM   #1
Default Traxxas audio input voltage
My 6 yr old just purchased a truck with the Traxxas audio system in it. I immediately have swapped out the brushed kit for his Brushless 3900 kit and am getting ready to splice in the Audio box to the different ESC.
I am unable to locate ANY voltage input specs on the audio unit. The XL5 shows a BEC output of 6 volts but this has been swapped for a brushless ESC.
I have written support for Traxxas and have not yet heard back from them.
MY QUESTION:
Can you locate any information that shows me I can wire the input for the audio unit directly to the ESC battery in wire to provide 8.4 volts input to the audio unit?
Do I need an external BEC to reduce the voltage to 6 volts?
He also runs the ESS-ONE unit on his Wraith and I know the specs show it can handle up to like 25 volts without issue, but I need to feel safe hooking the Traxxas unit up to 8.4 volts without a reduction.
Outlawaresee is offline   Reply With Quote
Old 02-17-2016, 02:12 PM   #2
Default Re: Traxxas audio input voltage
Ok, here's the spill from Traxxas.
Evidently the Audio box has it's own built in BEC and can be hooked up to any cell battery without issue.
Good to know!
Traxxas audio input voltage - Similar Threads
sanwa rx-371w input voltage crawlinghulls Electronics 14 12-02-2015 05:15 PM
MG996R Servo input voltage Outlawaresee Electronics 14 08-31-2015 01:57 AM
Max Voltage Input For Micro Crawler stomper4x4.com Losi Micro-Rock Crawler 8 12-12-2009 08:24 PM
input Voltage on a JR9100t? BEELZEBOB Electronics 2 11-17-2009 02:15 PM
Moped Input Voltage? Offroader5 Electronics 4 03-08-2008 04:57 PM
