03-10-2016, 10:05 AM | #1 |
Quarry Creeper Join Date: Jul 2010 Location: The Ocean State
| Mamba Monster X
Just picked up a MMX and I have a few questions for the guys running them. I'm running a Hitec 7950TH and will the internal BEC be sufficient? Next question has to do with drag brake on the fly, I am running a 2 speed and want to sync the drag brake with low gear. Has anyone been able to do this and how if so. I'm also thinking about scrapping the 2 speed and just running the drag brake off my 3rd channel. Thanks for looking!!! |
03-10-2016, 05:52 PM | #2 |
| Re: Mamba Monster X
Anyone... Sent from my LG-H900 using Tapatalk |
03-10-2016, 06:17 PM | #3 |
Quarry Creeper Join Date: Aug 2014 Location: sacramento
| Re: Mamba Monster X
I'm using the mmx and it's running a mks bls380 at 8v no problem, I have my drag brake set up on my third channel as a linear swich so I can adjust it on the fly, I have the dx4c so I still have a 4th channel for 2speed/dig/ lights ect, but if you only have 3 channels, I'm guessing you could just have your 3 channel set as a 2 position switch with a y harness and have the servo for the w speed and the mmx aux hooked up and it would change the two speed low and high and the drag brake would be off and on ( on for low gear I'm guessing is what your looking for?) Just a guess but might work I don't have a 2 speed trans to try it out |
03-11-2016, 09:00 AM | #4 |
| Re: Mamba Monster X
Thanks for the reply, I'll pick up a y adapter and see if I can get it to work!!
03-11-2016, 09:37 AM | #5 |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
| Re: Mamba Monster X
Let us know how it works out please and thank you.
03-12-2016, 12:06 AM | #6 |
| Re: Mamba Monster X
I'm running 2 MMXs now. Both set with 7.5 volts going to the servos and I've had no hiccups of any kind. The internal BEC seems to be more than sufficient.
03-12-2016, 09:37 AM | #7 |
| Re: Mamba Monster X
Can anyone tell me the base settings for the MMX and a Holmes Puller Pro 3500kv. I'm new to the whole brushless thing and have no clue as to what I'm doing with this MMX.
03-12-2016, 11:53 AM | #8 |
| Re: Mamba Monster X
I'm running that exact combo. I'm running medium startup power, 20% punch, flat throttle and brake curves and just adjust expo at the remote, and this is on 3s.
03-12-2016, 12:29 PM | #9 |
| Re: Mamba Monster X
Are you running drag brake off the aux? Not sure where to set that at Sent from my LG-H900 using Tapatalk |
03-12-2016, 03:52 PM | #10 |
| Re: Mamba Monster X
Yes, drag brake off the Aux set at 100%
Mamba Monster X - Similar Threads | ||||
Mamba Monster 2200kv with Mamba Max Pro | jordanbottle | Electronics | 6 | 05-21-2015 04:48 PM |
