02-11-2005, 11:17 PM | #1 |
| Motor troubles/confusion PLEASE HELP!
In my Twin,I've been running one of the stock cans. Seems like I remember reading somewhere that they were 27T but I could be wrong. I just tried running my new 55T lathe motor and was HIGHLY disapointed. With the stock motor,I was getting about 15 to 20 minutes run time. The torque though was kindly pitafull at times,even with the 3.8 geared GD 600. I figured a 55T lathe motor would fix me right up,torque wise and add some run time as well. Either I got a bad motor,new,out of the box,I've got something wired wrong or these 55T lathe motors truely blow on Bo Bo's big purple nose. I've ended up with less torque(it seems like anyway) and at most 5 minutes run times. It can't be the batteries. They are both Reedy 3000 stick packs,may not be top of the line but.................. With either one in my Twin with a stock motor I get better torque and more run time. I can also put both batteries in my sons Emaxx(12 tooth pinions,2 stock Titans and LST's) and run it hard for 15-20 minutes. I've not changed anything but the motor. I would think it has to be something in the motor or I've goofed on the end bell. Does anyone have a picture of the back of their 55T lathe motor,hooked up and in the car ready to run? That way I can confirm that I've got it right or wrong. What other problems could this be? PLEASE HELP |
02-12-2005, 12:15 AM | #2 | |
Break them in? I didn't know I had to break them in. 4 cell pack,DAMN, ain't got one. I don't really want to even think about trying to solider anymore cells together. I have a hard time solidering wires together,let alone batteries. Oh ya,it's an Integy | |
02-12-2005, 06:04 AM | #3 |
im stumped, unless your timing is set to 90 degrees. does the motor get hot when you run it? how about your ESC?
02-12-2005, 10:06 PM | #4 |
O.K. mesh as in gear mesh,nope,not to tight. I can lightly turn every gear between my motor and driveshafts with my finger and feel just a butt hair of slack. I'm possative there can't be any bind there. The charger I'm using is an Integy 16x4. Setting #4 allows you to cycle the battery to erase memory,it takes about 3 hours. I went ahead and tried cycling 1 of my batteries and then running it. I now can tell part of it was my batteries. I've not tried the cycled batteries in my sons Emaxx yet but I would asume there will be a big difference there also. These 55T's do have more power or torque,however you wanna say it,than my stockers. The thing is,I was running without my body,I noticed little sparks inside the motor. I quickly unpluged the battery and stopped running it. I don't,or didn't think this was normal. Is it? :? If it's not,whats the deal? Can it be fixxed? |
02-13-2005, 12:43 AM | #5 | |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
The sparks are normal in electric motors. It is called arching, and it is caused by the brushes bouncing on the commutator (due to an out of round comm.). | |
02-13-2005, 12:50 AM | #6 | |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
02-13-2005, 01:00 AM | #7 |
P.S. With my set-up (check sig) and a 2400 mah battery I can run for at least an hour, probably more. I just installed lathe motor too. I put it in truck and ran it lightly for a few minutes w/ it in my hand. This was my "break in method" Once in a while I get a little hic-up in reception, but I know that's my cheesy antenna routing. I haven't installed any caps on motor yet either. |
02-13-2005, 01:56 AM | #8 | |
It ran good and I ran it for about 45 minutes without any loss of power. I was gonna keep going but I was going from one obsticle to another,about 30 or 35 feet apart. I held it wide open the whole way bewtween and as soon as I just about got to the next obsticle the motor started smoking. SURELY this isn't "normal". I can't seem to get a break with this crap. Whats the deal? This crap is starting to piss me off. I should or would think my set up is O.K. and I should get about an hours run time. I'm running an EVX set up for 1 motor/battery,3000 mah battery,3.8 GD600,1 945 Hitech,Traxxass rec. and a Trinity rec. pack. | |
02-13-2005, 03:00 PM | #9 |
sounds like a short in the motor to me. can you take the endbell off and inspect the wires?
02-14-2005, 07:35 PM | #10 |
Well,I guess I could? Wouldn't really know what to look for but I'll try it. Maybe the problem will stand out to me.
02-14-2005, 08:17 PM | #11 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
Davids TXT-1 does the same thing. It's due to haveing such low gearing-when you run a motor wide open with low gearing it puts little resistance on the motor so things get hot. It's alot like keeping a real car at full throtal in last gear on the interstate for 10 or 20 minutes So really it's not abnormal but then again it's not a good thing either ;) |
02-14-2005, 09:25 PM | #12 |
Well,I'm wondering and have been for a couple days now,if a Magnetic Mayhem would suit me better. I'd like to know the difference between the 2. Anyone care to comment? Thanks guys. |
02-14-2005, 09:50 PM | #13 |
Rock Stacker Join Date: Jan 2005 Location: Fort Collins
Something must be hooked up wrong or wrong with the motor. Did you alter the timing of the motors? There should be a little notch on the can, align that with the endbell screw and you will have zero timing which is best for crawling applications.
02-14-2005, 10:00 PM | #14 |
I've not changed anything with these. I pulled them out of the box,solidered the wires,tightend my pinion down and bolted it up. I'll pull the end bell off to look tommorrow but I'm kinda thinking of getting a couple Magnetic Mayhem's,i dunno,not real sure just yet.
02-15-2005, 12:59 PM | #15 |
Rock Crawler Join Date: Aug 2004 Location: woods cross utah
are they the red or black end bell?
02-15-2005, 01:58 PM | #16 |
What is your overall gear reduction through the whole drivetrain? Lathe motors turn much less rpm than even a stock can. If you are geared too low the motors will seem like they suck because you have to try and spin them too fast to move your rig the same speed as before. 55T motors werk great in Clods because they only have 48 to 1 gear reduction (w/ an 8T pinion). |
