10-02-2016, 03:03 PM | #1 |
Quarry Creeper Join Date: May 2012 Location: vernon bc
| Futaba 4px question
I am needing to decide if I'll take another 4pls or upgrade to a 4px.. But I would like to know if the 4px has the same stupid trigger the 4pls has? Or is the trigger adjustable like the spektrum dx4r pro? I recelty sold my dx4r pro, bought two 4pls's one which arrived with a bad throttle pot. When I tried the working 4pls out I just can't fit my finger in the trigger opening. or will I be stuck using a dremel to make the opening larger on either one? Thank you |
10-03-2016, 01:44 AM | #2 |
Pebble Pounder Join Date: Mar 2016 Location: westminster
| Re: Futaba 4px question
4PX is great but do you want to take such a nice radio like that into the field. I have an M12 and cringe when I use it in the field as i don't want to set it down or slip and fall with it in my hands. I use my M12 for touring car races so ill save it for that but will get a slightly cheaper MT4 cause it has the same features but is slower in latency.
10-04-2016, 02:09 PM | #3 |
I'm not to worried, I'll get a hard case for it and it's getting a wrap as well.
10-04-2016, 02:22 PM | #4 | |
| Re: Futaba 4px question Quote:
I've used a M12 for years on my crawlers, it is no worse for wear than any other radio it's age. | |
10-11-2016, 06:13 PM | #5 | |
Quarry Creeper Join Date: Jul 2013 Location: PA
I had a 4pls for 3 years and loved every second of ownership. Recently I sold it and upgraded to a 4PX. I mainly did this to see if I could get more range for use with my speed run cars. However it didn't change at all. I will tell you the trigger is adjustable! Both position and tension. Also many people sell aftermarket triggers. I also find setting up the radio is much more intuitive. Hope this helps! Quote:
10-11-2016, 07:28 PM | #6 |
Newbie Join Date: Sep 2016 Location: Texas
If you only run scale/crawler, I would stick to the 4pl, the 4px offers a few more options and over double the price. Futaba is coming out with the 4pv which is a much better option than both, Its a cross between the 4px with a lower price closer to the 4pl. That is if you can wait. Hope this helps.
10-11-2016, 10:04 PM | #7 |
Thanks for the help guys, the 4px is on its way here. The cost was not the issue. I could have cut the trigger on the 4pls but didn't want to void any warranty for what ever reason. I also have a losi 5ive but 90% of the use will be MOA. So not out in the rain or mud often or at all.
10-12-2016, 07:52 PM | #8 | |
You wont regret the 4PX. The extremely intuitive Menu system is worth the added cost. I am running Castle Telementry Link on a few of my cars and trucks, Voice alarms are very helpful(speed run application). I also love the rear chest button. On my crawler I use it for Front Dig on and off. Really nice feature I never knew I would use... | |
Futaba 4px question - Similar Threads | ||||
futaba 4px | vegas1973 | Electronics | 0 | 05-23-2016 01:07 PM |
Futaba 4PX Battery Question | darkstar | Electronics | 2 | 02-15-2015 10:39 AM |
