01-19-2007, 04:43 AM | #1 |
Newbie Join Date: Jan 2007 Location: australia
| esc woes
hello all, i need help on an issue. the specs are 11.1v 3-cell 2100mah li-po through a mtroniks viper truck esc (12v rated) powering twin 65t integy motors on The Stick chassis. my problem started as glitching that affected both steering and throttle but has ended with the esc showing no lights or any signs of life at power-up. if its the esc then why the steering glitching? and if its the receiver then why no lights in esc at startup? the battery was compliant with esc specs (that i could find). any help would be greatly appreciated |
01-19-2007, 07:36 AM | #2 |
RCC Addict Join Date: Dec 2004 Location: Central NY
Why did you post two of the same thing, but change the battery size? You need to get your facts straight. Are you running 7.4 or 11.1 lipo?
01-20-2007, 06:09 AM | #3 |
| my bad
sorry, my mistake, still new to forum life. 11.1v 2100mah 10C are the accurate specs
