01-20-2007, 08:41 PM | #1 |
| HS-5955TG issues?
I picked up some new servos...an HS-5955TG and an HS-985MG. The question is...I have read some threads on here regarding the 5955's overheating and burning themselves up. I see on The Crawler Store's website, that they recommend a voltage regulator if running two of them. I realize I am not running two, but I want to make sure I get these hooked up right to not burn them...and also at the same time would like to know if I will have enough power to run both of these servos. I run 7 cells and a TR2 (so I assume I will have enough BEC?) Thanks for any info. |
01-20-2007, 08:53 PM | #2 |
Pebble Pounder Join Date: Dec 2006 Location: Peoria, AZ
The TR2 will give you more than enough. 3 amps will run two servos, so 5 amps should have no problem running one.
01-20-2007, 09:12 PM | #3 |
I wanna be Dave Join Date: Mar 2006 Location: One Legend.
7 Cells will drop the amperage of the BEC slightly. You may still be OK. It won't cause your servo to burn out, you'll just get glitching. What you really need to worry about with those servos is getting the end points set. They will burn up fast if mechanically limited by your steering throw. You need a radio that lets you set EPA or have a VERY good steering setup. |
01-20-2007, 09:18 PM | #4 | |
01-20-2007, 11:29 PM | #5 |
Quarry Creeper Join Date: Feb 2006 Location: Tweaking my shaft
Offroader5, I have those exact servos and ESC on my TXT. The BEC will not handle that combo, I know this. After the TR2 gave up the ghost, I installed a MPI servo regulator to let the new TR2 be happy, and to feed the servos the current they need. Here's the link to my post about the regulator:MPI servo regulator install The servo regulator output amperage will be a little less with 7 cells vs 6 cells, but it should work better than the BEC. |
