11-20-2016, 02:55 PM | #1 |
Rock Stacker Join Date: Nov 2016 Location: somewhere very rocky
| Yeti ESC to motor wire issue
My stupid yeti decided to break again!! The motor will get stuck in drive and reverse and it sounds like it is stripping of the spur gear. Does anyone else have this issue? Also the A port in the ESC is loose and comes out every few minutes. does anyone have that issue or a fix? Thanks! |
11-20-2016, 04:42 PM | #2 |
Rock Crawler Join Date: Apr 2010 Location: Eastridge Tn.
| Re: Yeti ESC to motor wire issue
Call or email axial..I'm pretty sure they had a recall on the esc's and will send you a new one..hope this helps...on the spur gear make sure the pinion alignment is right buy using copying paper to gauge the distance between the teeth Sent from my SM-G930T using Tapatalk |
11-20-2016, 07:11 PM | #3 |
Quarry Creeper Join Date: Nov 2014 Location: Reno
Pull the motor plugs at the esc clean them with light sand paper or scothbrite . The plugs are split at the end try to separate them a little so there is is a snug fit back into the esc Donner Party Crawlers. D.P.C. Last edited by BigBlokBoi; 11-21-2016 at 07:05 AM. |
11-20-2016, 08:04 PM | #4 |
Thanks no clue they were recalled didn't send me a letter.
Yeti ESC to motor wire issue - Similar Threads | ||||
ESC or motor issue | scott1981 | Axial Yeti | 19 | 11-24-2016 09:38 AM |
Motor/esc issue | Crawlininga | Axial Yeti | 3 | 09-01-2014 11:13 AM |
Viable ESC for Wraith with 2 wire motor ? | Bubonik | Electronics | 4 | 06-09-2014 03:08 PM |
NEED HELP PLEASE!! ESC/Motor Issue | mcap | Electronics | 4 | 02-10-2012 09:43 AM |
