01-22-2007, 01:01 PM | #1 |
Newbie Join Date: May 2005 Location: reno
| 55t Vs 75t
Wgat are the main differences between 55 and 75.Will the 75 have less wheel spin and be equivalent to running a 55t and dropping a pinion tooth or two? I assume it would turn slower and in turn be what I described above.Please chime in Thanks |
01-22-2007, 01:47 PM | #2 |
Rock Crawler Join Date: May 2006 Location: Surrey, BC, Canada
Check this out... It doesn't have a 75 but it has a 65 and others that should give you some kinda comparison formula that should answer your question... RC Crawler Definitive Motor info... It's more than just dropping a tooth or 2... |
01-22-2007, 03:15 PM | #3 |
So do you think the lower rpm would translate into less wheel spin and in turn act as a lower gear ratio?
01-22-2007, 04:29 PM | #4 | |
01-22-2007, 04:39 PM | #5 | |
RCC Addict Join Date: Dec 2004 Location: Central NY
01-22-2007, 04:44 PM | #6 | |
