02-07-2017, 07:27 PM | #1 |
Rock Stacker Join Date: Oct 2008 Location: In the Middle of a Corn Field
| Wire Management
I was wondering what everyone does for managing wires and keeping them neat? I am working on my Tamiya Semi and I need a way to bundle the wires nicely, however be able to undo them if needed. I heard their is a kind of tape that only sticks to itself. I am not able to find it. Any ideas would be appreciated. |
02-07-2017, 07:47 PM | #2 |
Rock Stacker Join Date: Nov 2013 Location: Victoria, BC Canada
| Re: Wire Management
You could use split loom. I tend to just heat shrink all my wires or cover them in braided wire loom and heatshrink the ends but that method won't make it easy to undo. Sent from my Nexus 5X using Tapatalk |
02-07-2017, 08:11 PM | #3 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
| Re: Wire Management
split loom, plastic "P" clips, adhesive zip tie retainers, small zip ties... You could even go as far as cutting down all your receiver leads to size and then putting new ends on them, which looks really nice as it eliminates excess wire completely. An old racer trick is to coil your servo wire(for example) around a piece of small tube and use a lighter to give it some heat. Leaves you with wires that are coiled up neatly. |
02-07-2017, 09:56 PM | #4 |
RCC Addict Join Date: Sep 2014 Location: Alberta
| Re: Wire Management
Braided loom
02-07-2017, 10:07 PM | #5 |
| Re: Wire Management
Another thing for wire management is to reduce the amount of wires. Been doing this for years. Best $21 ever spent. Servo Connector Crimping Pilers .... |
02-08-2017, 02:14 PM | #6 | |
Newbie Join Date: Jun 2016 Location: california
| Re: Wire Management Quote:
02-08-2017, 02:27 PM | #7 |
| Re: Wire Management
I've tried the plastic wire nets. I can't ever find a good size that will go over plugs yet still keep the wires tight.
02-08-2017, 10:13 PM | #8 |
Rock Crawler Join Date: May 2013 Location: Uniontown
| Re: Wire Management
More money I don't have for tools and supplies I don't absolutely need, lmao. Sent from my XT1585 using Tapatalk |
02-09-2017, 01:12 PM | #9 | |
Silicone Self-Sealing Tape,No HTP-1010, Gardner Bender Inc | eBay | |
05-18-2018, 08:37 AM | #10 |
| Re: Wire Management
Reviving this guy... What size of mesh wire loom would be good for brushless motor wires (Castle 1400 series)? The two sizes that seem right are 3/8" and 1/2". |
05-18-2018, 10:48 AM | #11 |
| Re: Wire Management
I'd like to know how people get the wires in the mesh without tearing the mesh apart...
05-18-2018, 11:13 AM | #12 |
Quarry Creeper Join Date: Jan 2017 Location: Olathe
| Re: Wire Management
Most of mine is done with shortening the wires and careful routing. For my axle mounted servo I ran the servo cable up one of the upper suspension links with a piece of black heat shrink tubing. I also like to use heat shrink to bundle wires up or to shorten wires. Take a long servo cable and fold it back on itself twice and then put heat shrink over it and it tighten around the wires and hold them in place. |
05-18-2018, 11:34 AM | #13 | |
I'd be afraid of scorching my servo wires when heating the shrink tube. | |
05-18-2018, 11:56 AM | #14 |
Rock Crawler Join Date: Jan 2014 Location: Frog Lake AB, Canada
| Re: Wire Management
I use the outer carcase of parachute cord to dress up the wires, if I need to sleeve it over a connector, then I just remove the connector then re-solder the connector back onto the wire. Don’t be afraid of the heat while using shrink tubing, it’s not like you need loads of heat. I’ve been using a hairdryer set on the low setting. |
05-18-2018, 02:02 PM | #15 | |
Rock Crawler Join Date: May 2016 Location: SoWIs
| Re: Wire Management I'm surprised nobody mentioned velcro straps (pic link). You can get rolls with male/female on each side, then cut a small piece and roll it around the wire onto itself. I use this for all types of cable management besides real cars. You can also use elec. tape, as that's what's used to pre-bundle car wiring before putting it into split loom. One thing to note, power wires that are run parallel with signal wires can cause problems. So can power wires that are coiled up. Quote:
Usually it's just zip ties and/or shrink tube. As for scortching the wires, just don't use a flame nor soldering iron. A $10-25 heat gun with 2 settings is ideal and has many other uses. | |
05-19-2018, 01:58 PM | #16 |
Pebble Pounder Join Date: Jan 2018 Location: Spain
| Re: Wire Management
A RC car wire management is a piece of cake but good for learnings. Try a 16 channel jet plane, that is serious issue... The key to a safe and nice wire management is time. Spend time calculating it, routing it and exploring different options. Then just use all materials needed: zip velcro ties, neoprene, shrink tube, etc. But spend time thinking and testing how to do it. |
Wire Management - Similar Threads | ||||
Anger management | khwilliams | Chit Chat | 2 | 08-30-2011 07:41 PM |
Ok so we are 100% under new management | bigboystoysnm | New Mexico | 12 | 08-27-2011 04:55 PM |
Frequency Management | SVEN | RC Rock Crawling Worlds | 58 | 09-06-2007 09:15 PM |
Frequency Management | jason | RC Rock Crawling Worlds | 47 | 07-15-2006 12:27 PM |
