03-06-2017, 03:53 AM | #1 |
Newbie Join Date: Feb 2016 Location: Singapore
| GoolRC 3660 3800KV Motor & Waterproof 60A Brushless ESC
Does anyone heard about this! Does the specs says it is a good to buy or not? Product Description The original upgrade waterproof 3660 3800KV brushless motor with 60A ESC combo is designed to provide both quality and performance at an affordable price. Waterproof function motor and ESC let your car challenge the muddy road. Providing much convenience for your 1/10 RC car truck. PSClick the link to watch the product video: https://www.youtube.com/embed/PZ3c92A6isM Features: 4 pole 12 slot high-torque motor design 5mm shaft diameter High purity copper windings maximizes efficiency Precision engineered for maximum energy conversion Precision balanced rotor,smoothness for best reliability and maximum RPM Mutiple protection features: Low voltage cut-off protection, over-heat protection, throttle signal loss protection Bulit-in 5.8V/3A BEC Suit for 1/10 scale RC car Motor Specifications: Brand name: GoolRC Watts: 1200W Max voltage: <13V Max Amps: 92A KV(RPM/Volt): 3800KV Max RPM: 50000 Diameter: 36mm Length: 60mm Shaft length: 17mm Shaft diameter: 5mm Plug type: 4mm golden banana plug ESC Specifications: Brand name: GoolRC Item name: waterproof ESC Continue current: 60A Burst current: 320A Battery: 2-3S Li-Po / 4-9S Ni-Mh Ni-Cd BEC output: 5.8V / 3A Power supply plugs: T plug male Motor plugs: 4mm banana plug female Dimension: 50 * 35 * 34mm / 2.0 * 1.4 * 1.3in (without cables) sent by Wehlee |
03-06-2017, 04:09 AM | #2 |
RCC Addict Join Date: May 2009 Location: Weston
| Re: GoolRC 3660 3800KV Motor & Waterproof 60A Brushless ESC
Not good.
03-06-2017, 06:35 AM | #3 |
| Re: GoolRC 3660 3800KV Motor & Waterproof 60A Brushless ESC |
03-06-2017, 06:48 AM | #4 |
Nope. He asked if the specs say if it's good. I say no. Weak BEC, weak ESC, looks like it's not sensored and he didn't say what it was for.
03-06-2017, 06:50 AM | #5 |
I know it might not always be true but in my experience you get what you pay for, especially with electronics.
03-06-2017, 12:12 PM | #6 |
The specs on that motor look the same as the Hobbywing I've got in one of my trucks. It has plenty of power, and I have no complaints in its intended go-fast application, but it would be far from ideal in a crawler. That ESC is too small for that motor in my opinion. You've got a motor that can pull nearly 100amps constant paired with a 60a esc... the "burst rating" of 320a is probably good for 3-4 seconds before it overheats, do you want to baby the throttle all the time, or do you think it will never be under load for more than a couple seconds? Couple that motor with a 120a esc and I think you'd be fine. If it's going in a crawler, I'd either go with a lower kv, or go sensored. |
03-09-2017, 12:17 AM | #7 | |
| Re: GoolRC 3660 3800KV Motor & Waterproof 60A Brushless ESC Quote:
I personnaly do not know about electronics so i've ask query. So, people like you who are knowlegable can help. I am planning on installing it on my RR10 Bomber. I am kind of tight with budget. sent by Wehlee | |
03-09-2017, 12:20 AM | #8 | |
I like crawling and a little bit of bashing so to speaks. Zero knowledge with electronics. sent by Wehlee | |
GoolRC 3660 3800KV Motor & Waterproof 60A Brushless ESC - Similar Threads | ||||
Any input on goolrc sensored brushless esc | bro_die | Electronics | 5 | 01-26-2017 04:34 PM |
1:10 Duratrax Baja Bug with 60A ESC and Brushless motor RC Adventures at Durian Loop | boolean21 | Scale Videos! | 0 | 05-15-2013 09:40 AM |
Venom 540 55T BRUSHED+60A WATERPROOF ESC COMBO | 8ball ice | Electronics | 0 | 01-06-2013 07:41 PM |
