03-06-2017, 08:17 PM | #1 |
Quarry Creeper Join Date: Nov 2007 Location: Nor-Cal; Olivehurst/Yuba City
| Need help w/crawlmaster pro 16t
Last weekend was my first time out with my revamped rig. It's based around a Brazinscale Team Chassis. XR modded Ottsix axles with od/ud. Wheels are vp with flat irons (1.9). Full droop. Transmission has full metal gears. Crawlmaster pro 16t on 3s. Gearing is 10/58. Holmes brxl and airtronics m12. While on the trail I tried to go up this off center ledge that goes near vertical . The area is granite. Anyways, I tried to slowly go up, I had nothing until full throttle. No slow speed crawl. But on the ground I had no issues. Any ideas on what it could be? I've had the esc for awhile and never had any issues. Thanks for your time Sent from my iPhone using Tapatalk |
03-07-2017, 08:29 PM | #2 |
Quarry Creeper Join Date: Sep 2015 Location: Bakersfield
| Re: Need help w/crawlmaster pro 16t
Yeah, that's strange. Is the m12 new as well? Did you calibrate the throttle? Maybe the throttle curve/expo is cranked up too far? I'm just grasping at straws and interested in learning what it is. That 16t on 3s should have plenty of torque. |
03-08-2017, 02:29 PM | #3 |
Yeah the m12 is new. I changed the timing by from 0 to 6 and that helped. I need to look at the manual and see if I need to dial in some of the radios functions Sent from my iPhone using Tapatalk |
03-08-2017, 02:34 PM | #4 | |
| Re: Need help w/crawlmaster pro 16t Quote:
Thanks for more info, I'm thinking reset all tx settings to default, check the manual, adjust as needed and try again. Post back how it goes bud. | |
Need help w/crawlmaster pro 16t - Similar Threads | ||||
HH Crawlmaster 16T vs. HH Team Pro Flow 35T. | AddictedtoRC1 | Axial XR10 | 17 | 12-06-2012 08:36 AM |
