04-07-2017, 10:57 PM | #1 |
RCC Addict Join Date: Feb 2017 Location: Surprise
| Each channel with a Y-harness
Is it ok for me to use a y-harness on each channel on the receiver ? Example channel 1 a y-harness, servo and lights....2nd channel, esc with the bec....3rd channel lights and a glitch buster , is it ok to do that to all the channels ..... I hope I explained myself right.... Sorry if I didn't ...... Thanks guys really appreciate it, and this community ....
04-07-2017, 11:14 PM | #2 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: Each channel with a Y-harness https://www.rpphobby.com/product_p/gea1094.htm https://www.rpphobby.com/product_p/gea1309.htm Use either of those on 3rd channel for lights. And bind port put the glitch buster. I would leave esc channel alone and if your using a holmes rx bypass on servo channel, then that's fine. |
04-08-2017, 02:56 PM | #3 |
Rock Crawler Join Date: May 2016 Location: SoWIs
The pins on the receiver are all directly connected via circuit board traces, so it won't be a problem. I wouldn't go over 5 amps peak, as that's probably nearing the limit of the traces.
04-08-2017, 08:09 PM | #4 | |
| Re: Each channel with a Y-harness Quote:
I had to Google circuit board traces.... Just learning ,thanks ... | |
04-09-2017, 07:18 PM | #5 |
If the BEC is feeding the receiver (the first thing it's plugged into), then yes try not to go over. Each LED is usually 0.02A though. If the BEC connects to that device 84yoda posted, then go crazy.
Each channel with a Y-harness - Similar Threads | ||||
Can I Run 2 Fans With Y-Harness In Battery Channel AR-3 | rustneversleeps | Electronics | 7 | 07-06-2015 09:55 PM |
Y-Harness | armedtotheteeth | Electronics | 4 | 01-21-2006 09:55 AM |
Y-harness | Rooney7783 | Electronics | 3 | 10-04-2005 12:30 PM |
