01-28-2007, 03:58 PM | #1 |
Newbie Join Date: Apr 2006 Location: Calgary, Canada
| e-maxx evx question
I have lost the forward/reverse function on my traxxas e-maxx. The steering and transmission servo still work.I is my evx toast? Nothing looks out of the norm and everything seems to be hooked up properly.It doesnt help that my electronic skills are not the greatest
01-28-2007, 04:30 PM | #2 |
I joined the Band! Join Date: Sep 2006 Location: ...
i know that the esc gives the servos power. do you have a battery box made by traxxas? if you do put the batt box in the battery slot, then hook your steering servo to the throttle connection. if the servo works your recievers fine. if it doesnt, replace the reciever. idk exactly what the button does on the esc. maybe do some reasearch or look in the owners manual and try to find out what it does. can you tell me IN DETAIL the last time you drove it? did you go through mud, water, ect.
01-29-2007, 07:14 AM | #3 |
Quarry Creeper Join Date: Aug 2004 Location: North Las Vegas
What you can do is suspend the truck in the air and switch the esc and steering servo wires so they are on different channels. Then turn on the truck and see if by turing the wheel your truck goes in forwards or reverse. If you truck moves, then your receiver is dead. If it doesn't then it's the esc. Double check the wires to the motors to see if they are cut or not. Breaking inside the wire is impossible to see. Did you get your esc wet?
01-29-2007, 03:11 PM | #4 |
thats exactly what i just said?^^^^^^^^^^^^^^^^^^^^^^^^^^ just in a difforent form
01-30-2007, 11:36 AM | #5 |
Quarry Creeper Join Date: Nov 2005 Location: Planet Earth
It could be a connection anywhere in the circuit/battery. (the dummy battery side)
