05-24-2017, 11:27 PM | #1 |
Pebble Pounder Join Date: Aug 2016 Location: N/A
| Shortening leads on a HH Puller Pro
I plan to tidy up my wiring by shortening the power leads on my HH Puller Pro 3500kv. Are there any problems associated with this? (I know some motors/ESCs have wiring that can only be soldered at the very end of the wire, so cannot be shortened).
05-25-2017, 06:18 AM | #2 |
| Re: Shortening leads on a HH Puller Pro
No problems shortening the wires on a Puller Pro. Cutting and reinstalling the bullets will be the easier way, especially if you don't have a good soldering iron. The motors that you can't shorten the wires on are usually unsensored ones with really stiff wires that go straight into the can (because the wires are extensions of the windings). Motors that use external solder tabs, like the Puller Pro, don't have that issue. |
05-25-2017, 11:52 AM | #3 |
Thank you!
05-25-2017, 01:58 PM | #4 |
Rock Stacker Join Date: Aug 2013 Location: NZ
+ 1. chop the plugs off / shorten wire. Solder or crimp on new plug. Easy |
Shortening leads on a HH Puller Pro - Similar Threads | ||||
Motor Selection Help Needed - HH Puller Pro 540 vs HH Puller Pro 540XL | WesTX | Electronics | 18 | 09-14-2016 09:16 PM |
Shortening ESC, BEC & Servo Leads | GodSpeed999 | Electronics | 16 | 03-16-2015 10:24 AM |
Fan Leads on Mamba Max Pro | DrDiff952 | Electronics | 2 | 11-21-2014 06:15 PM |
Shortening The Wheelbase? Theory to Shortening the links? | KIRK! | Tamiya CR-01 | 5 | 08-12-2011 12:40 PM |
