02-17-2005, 05:51 PM | #1 |
Lifetime Gold Baby! Join Date: Sep 2004 Location: GA
| electrical problem
ok...for some reason when my steering is in any kind of bind the speed control cuts power to the motor and then the servos start twitching like crazy...if I release the steering and pick the rig up and sit it back down after letting all the wheels return straight then it works fine again until I turn too sharp. I even replaced the reciever, speed control and transmitter and it still does it! I am running 2 high torque servos off a y harness could it possibly be drawing too much power from the speed control making it shut down? any help is appreciated.
02-17-2005, 06:28 PM | #2 |
Rock Stacker Join Date: Nov 2004 Location: tyler
I had the same problem and i put a rx battery on it and all of my problems were solved hope this helps
02-17-2005, 06:33 PM | #3 |
RCC Addict Join Date: Apr 2004 Location: Cincinnati Ohio
Ditto to what he said. What ESC are you using? |
02-17-2005, 06:44 PM | #4 |
I WAS running a tekin rebel and it was doin this stuff so I just bought a brand new duratrax Intellispeed and I'm still getting the same results. I'll try the reciever pack. what kind are you guys using just a standard 4AA pack or something more powerful? and thanks for the rapid replies.
02-17-2005, 06:48 PM | #5 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
yeah use a RX pack.... you would probably get more answers if this was in the right section though |
02-17-2005, 06:59 PM | #6 |
oops...didn't even notice there was an electrical section.sorry.
02-17-2005, 06:59 PM | #7 |
4 alkaline AA's will get you 6 volts. 5 AA rechargeables will get you 6v. I am using a cobbled together 4 cell plus a single cell NIMH battery pack made from 5 NIMH AA' rechargeable batteries. |
02-17-2005, 07:51 PM | #8 |
well I tried a standard 4 AA pack and it fixed my problem! that's great...but I didn't really want the added weight of the pack and the hassle of another pack to charge so just to see if it worked I ran a separate harness off the main battery's plug and plugged it into the reciever and walla...it still works with no problems and it all runs off the one battery pack. ( less hassle)
02-17-2005, 08:21 PM | #9 |
Just be careful. 7.2V to the servos could fry them. Or at the very least, reduce their overall life. Do a search for "regulator" in the electronics section if you want to use just one pack. |
02-17-2005, 08:32 PM | #10 |
well the reciever has BEC so I'm good...
02-17-2005, 11:42 PM | #11 |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
Moved to the electronis forum.
