12-15-2017, 06:28 PM | #1 |
Newbie Join Date: May 2017 Location: Altoona
| Lightbars
I need opinions on lightbars...I was looking at the Gearhead RC one’s and also a light kit from My Trick RC. I may just decide to run a light bar for now but may add headlights and such later on. Thank you in advance!
12-15-2017, 06:38 PM | #2 |
Newbie Join Date: Aug 2014 Location: Highland
| Re: Lightbars
I agree with just get a light bar and others later for scale look. The high mounted LEDs offer more usable light. Especially if you run them on 3S they are really made for 12V. I am thinking of updating my rig to run on 3S or just run a stand alone 3S 2200maH drone bat. just for the lighting with a voltage cutoff or limit alarm. I'm running a 5' Vanquish light bar and it is very bright on 3S. All of the other lights are just for show. I mounted some rear white backup lights in my rear bumper that come on with reverse and they are useful. I also mounted a red LED in each wheelwell for night crawling and that really helps. Otherwise it can look like a couple floating flashlights on the ground.
12-15-2017, 06:44 PM | #3 |
| Re: Lightbars
I also am looking to switch to a 3cell... how do you get the reverse lights to turn on when in reverse? That’s the one thing that I kinda liked about the My trick Rc light kits ...they come with a controller.
12-15-2017, 07:01 PM | #4 | |
| Re: Lightbars Quote:
The kit allows you to program how the light responds to the receiver. The reverse light programming was tricky. I had to call them to get it figured out. Good customer support. It's pretty sweet. I programmed the reverse signal to be off at neutral and come on at about 5% rev. throttle before he motor does anything. Pretty sweet. It was like I could just turn on the reverse lights without the rig moving. These controllers have high and low amp outputs and programmable intensity I think. It's been a while since I did all this. | |
12-15-2017, 07:26 PM | #5 |
| Re: Lightbars
HeyOK makes all the controllers you could want. If he doesn’t, he can Hang up and Drive |
12-15-2017, 08:01 PM | #6 |
| Re: Lightbars
Thank you! I will look into them both...I hope to be able to post some pictures soon!
12-16-2017, 07:25 AM | #7 | |
RCC Addict Join Date: Jun 2017 Location: Canada
I got the front lights + light bar on a controller in channel 3 running straight from the 3s battery and the rear brake lights linked to the throttle channel. I used 2 HeyOK controllers and it's perfect. Sent from my Nexus 6 using Tapatalk | |
12-16-2017, 07:33 AM | #8 |
| Re: Lightbars
I run two of them and his servo winch. Can’t go wrong with Al and HeyOK ! Hang up and Drive |
12-18-2017, 11:06 AM | #9 |
| Re: Lightbars
Thanks for the mentions! Let me post links to a few parts that might be of interest: Brake, Reverse and Driving Light controller $30 RC Switch with Lipo Cutoff Heyok: Rock Lights on a budget |
12-19-2017, 12:57 AM | #10 |
Quarry Creeper Join Date: Jul 2017 Location: Sweden
| Re: Lightbars
I've got the brake, reverse and light controller on my Yeti, and strongly recommend it. Small, cheap, easy to install, does lots of nice things.
Lightbars - Similar Threads | ||||
Vanquish lightbars | ochevys54 | Electronics | 0 | 03-19-2014 06:43 PM |
Integy Lightbars | SirKarnage | Electronics | 2 | 12-24-2013 11:45 AM |
Lightbars, School Me on Lightbars | hpiguy | Electronics | 7 | 11-01-2013 11:54 AM |
Vanquish Lightbars | OFFROADRCKOREA | Vaterra Twin Hammers | 2 | 04-11-2013 07:56 PM |
