03-04-2018, 03:12 AM | #1 |
Newbie Join Date: Jan 2018 Location: British Columbia
| Tactic TTX300 lanyard attatchment.
I had to search high and low for this after seeing it a while a go on the net. So after I found it again and added lanyard attatchment points to a couple of my controllers I thought I would share this. I started with the parts below but did not use the button head screws, instead I used the oversized head ones for attatching servo to mounts. I started by removing the screw where my driver is shown. Then inserted the 3mm grub screw into the thread from where I had previously removed to screw from. Next I threaded on the threaded pipe, then used the servo screw to attatch the picture hanger to the controller as seen in the last picture. Just thought I would share this because I hate finding a spot to put down my controller when I have to do anything. The post I found on the net used hot racing threaded pipes of the same dimensions as the axial ones. Sent from my SM-T580 using Tapatalk |
03-04-2018, 06:01 AM | #2 |
RCC Addict Join Date: Jun 2017 Location: Canada
| Re: Tactic TTX300 lanyard attatchment.
Can you do a part list? I absolutly need to do this to my rc4gs. Sent from my Nexus 6 using Tapatalk |
03-04-2018, 08:40 AM | #3 | |
| Re: Tactic TTX300 lanyard attatchment. Quote:
1 - 6 x 33 mm post Axial AX30517 or Hot Racing RCL63301 1 - 3 x 10 mm button head screw AXA0109 or AXA115 ( I prefer to first with the oversize head) 1 - 3 x 20mm set or grub screw AXA0187 1 - D shaped hanger (I found these at Homedepot in the picture hanging hardware) | |
03-04-2018, 12:26 PM | #4 |
Found an adjustable strap in my crap bins in the shop after driving around yesterday trying to find a lanyard that does not put the controller right at your chest. Going out today for a test run! Sent from my SM-T580 using Tapatalk |
Tactic TTX300 lanyard attatchment. - Similar Threads | ||||
Tactic ttx300 help | Bondoe Technology | Electronics | 0 | 07-17-2016 08:27 AM |
Tactic ttx300 help. | Bugs Crawler | Electronics | 0 | 03-16-2016 05:57 AM |
