Thread: Mamba max .vs. tekin 2
Old 02-06-2007, 01:08 PM   #1
Default Mamba max .vs. tekin 2
HI
i hear very good things about the mamba max.
Which esc can turn the motors slowest when needed to?
And what bec is the mamba max?
I have looked in my dad's manual but couldn't find it.
Thanks
james
Moondust1950 is offline   Reply With Quote
Old 02-08-2007, 02:58 PM   #2
well, i am not sure, but i put a post for mamba and s rooster, but i would like to know comparisons about teken rebel too.......thanks
5150bronco is offline   Reply With Quote
Old 02-08-2007, 03:13 PM   #3
There is no comparison between the 2 IMO
traylor4x4 is offline   Reply With Quote
Old 02-08-2007, 03:29 PM   #4
dezfan's Avatar
OK guys here is the skinny.
The Tekin Rebel 2, Novak Super Rooster, MOPED, ect... are all brushed ESC's w/ a history in crawling. They are not the onlt ESC's used, but they are very common.
The SR and TR2 are rated higher and cost more than the MOPED. But, they all function in basically the same manor.
The Mamba Max is the newest generation of ESC.
It can be used w/ brushed and brushless motors. It is up-datable via a USB cord through your PC.
It also has parameters that that can be changed to suit your personal desires or needs.
It also has a drag brake feature that none of the other ESC's mentioned have, this alone gives it a huge advantage over the other ESC's.
If you can afford it, get the Max and you will be set for the foreseeable future as ESC's go.
dezfan is offline   Reply With Quote
Old 02-08-2007, 03:33 PM   #5
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
bec on da MM is 3a @ 5v
bec on tr2 is 5a @ 6v
JohnRobHolmes is offline   Reply With Quote
Old 02-09-2007, 03:30 PM   #6
Dez,
thanks dude, very helpful, i guess i have decided with all the great help from everyone, i am going with the mamba max.
