03-13-2018, 03:55 PM | #1 |
Rock Stacker Join Date: Feb 2018 Location: Ozarks
| Pros/Cons: Mamba X vs. HH TrailMaster BLE Pro
Is anyone familiar with both the CC Mamba X and the HH TrailMaster BLE Pro ESC's? I'm having a hard time choosing one over the other. Unless I am wrong, it is my understanding that HH and CC work closely with each other so both should be excellent performers. I'm looking at running a HH PullerPro 3300K on 2S in my GMade GOM. Thanks. |
03-15-2018, 07:11 AM | #2 |
Newbie Join Date: Jan 2015 Location: Oklahoma
| Re: Pros/Cons: Mamba X vs. HH TrailMaster BLE Pro
I have not used the BLE Pro so not familiar with it.. I'm currently using the Mamba X and love the option for the aux wire function to adjust brake. I'm sure the BLE is an excellent ESC I just chose the Mamba X for the aux wire option. I'm currently running the Puller Pro 3300KV with 3S on my SCX10 II and must say it has plenty of getup and go. Pro's with the Mamba X would be the aux wire. when trailing you can adjust the brake and not have the vehicle trying to flip end over end. Cons: Have not found any as of yet other then a little confusing setting up the aux wire function with castle link but once you figure it out its not hard at all. BLE Pro: Reputation and Customer service is excellent. That's all I can say as I have not run the BLE Pro. Hope this can help |
03-15-2018, 10:54 AM | #3 | |
| Pros/Cons: Mamba X vs. HH TrailMaster BLE Pro Quote:
The BLE is a reflashed Castle MMP, without the fan or on/off switch. JRH has tweaked the firmware, But no Aux wire. You’ve got the best now. I run the BLE and the PP3500 in my Wraith , works quite well Hang up and Drive | |
03-17-2018, 05:24 AM | #4 |
Both are great ESCs. Either combined with a Puller Pro stubby will give you industry best startup, control, and power to weight. The mamba X is nice. Its a bit heavy, but the Aux function is cool if your radio has a spare channel. It also has better sensorless startup, which gives you more flexibility in the future. The BLE is lighter and has modes of operation that run with less noise. I typically grab a BLE for my personal builds because switching noise really bothers me. I love a completely silent rig when the setup will allow for it. |
03-25-2018, 04:53 PM | #5 |
Pebble Pounder Join Date: Nov 2005 Location: south jersey
I’m looking to go up to a 4s from a 3s. Currently running a microx with a pp2200. Will the ble handle a 4? I know the X will.
03-25-2018, 05:31 PM | #6 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Re: Pros/Cons: Mamba X vs. HH TrailMaster BLE Pro |
03-25-2018, 08:29 PM | #7 |
2s to 6s capable.
03-25-2018, 08:38 PM | #8 |
03-25-2018, 09:01 PM | #9 |
RCC Addict Join Date: Jun 2017 Location: Canada
03-25-2018, 09:11 PM | #10 | |
| Re: Pros/Cons: Mamba X vs. HH TrailMaster BLE Pro Quote:
Sent from my LG-M322 using Tapatalk | |
03-25-2018, 10:42 PM | #11 |
Directly from the HH website: TrailMaster BLE Pro 2S-6S (25.2V maximum) input on the other hand: Mamba Micro X Crawler Edition Input Voltage Range: MIN: 2S LiPo; MAX: 3S LiPo, 12.6V and finally: Castle Creations Mamba X 2S to 6S input voltage range |
03-30-2018, 06:58 AM | #12 |
I'm sorry, after re-reading my question it did seem confusing. I've been running a micro X on 3s with good results. Now I want to upgrade to 4s. I'll be replacing the esc with either a Mamba X or a BLE but wasn't sure if the BLE would run 4s. Thank you JRH and durok.
Pros/Cons: Mamba X vs. HH TrailMaster BLE Pro - Similar Threads | ||||
Trailmaster BLE Pro Issues | Vinster_Beta | Electronics | 8 | 08-31-2018 11:51 PM |
Trailmaster BLE Pro waterproofed | chevotafun | Electronics | 2 | 04-01-2016 02:24 PM |
