02-06-2007, 10:06 PM | #1 |
I wanna be Dave Join Date: Dec 2006 Location: here
| 55t lathe motor
Ok guys I got mine 55t lathe motor i need to reverse wires correct.So instead red on + red gose on -. Any help would be great If yes,Why do I need to do this |
02-07-2007, 07:05 AM | #2 |
Quarry Creeper Join Date: Oct 2005 Location: Bryant, AR
I think as long as the motor is at 0 degrees timing, it will be ok.
02-07-2007, 10:56 AM | #3 |
Rock Crawler Join Date: May 2006 Location: Surrey, BC, Canada
What are you puttin' the motor into? If it's a Clod, then yes... The rear motor needs to be wired backwards... If it's not a clod, then no... Wire it normally...
02-07-2007, 04:19 PM | #4 |
Newbie Join Date: Feb 2004 Location: Staten Island, NY
| 55T Lathe
I've got my 55T in my PRP TLT-1 and i like the torque without the excesive speed factor it really does well for trail running... Marty |
02-07-2007, 04:42 PM | #5 |
A TLT is single motor so it doesn't need to be wired in reverse... The only time you need to do that is on a Clod or similar where the motor position is 180 from the other...
02-08-2007, 05:50 AM | #6 |
the 55t motor is going in a maxxcrawler so just install normaly but set motor @0 drg. ???? |
02-08-2007, 06:33 AM | #7 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
the lathe is set to 0* now... put it in, wire it up and go.....
02-08-2007, 11:39 AM | #8 |
thanks guys. |
