Thread: Will brushed Quicrun program cards work with brushless Quicruns?
Old 04-04-2018, 05:36 PM   #1
Default Will brushed Quicrun program cards work with brushless Quicruns?
Hoping at least some of the features will work....
willygee is offline   Reply With Quote
Old 04-04-2018, 06:55 PM   #2
Default Re: Will brushed Quicrun program cards work with brushless Quicruns?
I was able to use my WP1080 brushed card with my 8BL150 card, both are 6mo old. IIRC there are 3 setting variations and it should work for all 3, you just need to know what a particular ESC uses for menu options. One card actually has 3 sets of option listings printed on front & back labels.
Hydrocarbon92 is offline   Reply With Quote
Old 04-04-2018, 08:18 PM   #3
This
Sent from my Nexus 5 using Tapatalk
MasteroFlego is offline   Reply With Quote
Old 04-04-2018, 11:37 PM   #4
I even used my 1080 card on a cheap ebay HW WP 60A knockoff, just look up the manual to see what's under which number.
Ninomaniac is offline   Reply With Quote
Old 04-05-2018, 06:29 AM   #5
Thanks guys for the response.I will be using the card with a 10BL60 in my TRX4..."crawler mode" as i dislike the double click reverse. Also,need to set whatever brake drag or other setting so my Defender doesn't stop suddenly when i reduce throttle ...more of a coasting mode.
Old 04-05-2018, 08:14 AM   #6
And I splashed out £8 on a new one let us know if it works!
Sent from my Pixel using Tapatalk
Crawler Cads is offline   Reply With Quote
Will brushed Quicrun program cards work with brushless Quicruns? - Similar Threads
Hobbywing Quicrun Waterproof 1080 Brushed Crawling ESC LSXGMC Electronics 450 06-27-2020 09:06 PM
QUICRUN 08 ESC Dual Brushed edan RC4WD Bully 15 04-26-2017 12:02 PM
QUICRUN WP 1080 brushed ESC (2-3S) With castle Bec Vwsb74 Electronics 14 04-07-2017 10:43 AM
Dynamite 60A Brushed ESC or Hobbywing Quicrun WP1060? MaX-D Electronics 1 09-12-2014 11:22 PM
brushless esc on brushed motor - will it work ? buju Electronics 5 10-14-2008 10:44 AM
