02-07-2007, 10:01 PM | #1 |
Rock Stacker Join Date: Jan 2007 Location: D-town
| mamba 25 question.......
ok before you say it...yes I did search,just couldn't find the answer. I am running a 2.2 rig I plan on competeing with(eventualy), single motor, and jr9000t servo... is the mamba 25 an option? will it work correctly with a brushed motor? I love the idea of how small it is,I'm using a dynamite esc I had laying around for now but it is HUGE.any info would be great... |
02-07-2007, 10:31 PM | #2 |
Quarry Creeper Join Date: Jan 2006 Location: Winston-Salem
You can run brushed and brushless motor with a Mamba.
02-07-2007, 10:32 PM | #3 |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
No, the Mamba 25 will not work with a brushed motor. It is only for brushless. The Mamba Max on the other hand can run a brushed or brushless motor. The Mamba Max is not as small as the 25, but it is tiny compared to other esc's with it's capabilities.
02-07-2007, 10:43 PM | #4 |
ahh a definitive answer....thanks Sven
02-07-2007, 10:48 PM | #5 | |
02-07-2007, 10:54 PM | #6 |
'08 2.2 National Champ Join Date: Nov 2006 Location: UTRCRC
I have a mamba max and I am extremely impressed with how adjustable it is. Even if you are using a brushed setup the adjustablility alone is worth the price.
02-07-2007, 11:04 PM | #7 |
just pulled the specs off the web,yeah a lot of features but that thing is darn big.....but after a little research I might wait for a tekin fxr,good features and its only 1.0x0.8x0.75,plus it has lipo cutoff built in.....
02-07-2007, 11:16 PM | #8 | |
From teamtekin.com: On Board temperature indicator PC Interface for custom programming via TekinCom Solder posts Self diagnostics and factory reset Pit Tune mode Digital Glitch filtering QuickTune one touch programming One touch radio calibration Program Features: Drag Brake (13 steps) Brake/Reverse Strength (none, 12 steps) Push- Anti Drag (13 steps) Throttle Profiles (7 choices) Voltage cutoffs (none, 6v, 6.5v, 9v, 12, 12.5v) Fwd/Brk/Rev 7cells/2s Lipo 14 turn motor limit BEC: 6 volts/ 3 Amps Dimensions: 1" x .8" x .75" On Resistance: FXPro .00013 Ohms | |
02-08-2007, 09:06 PM | #9 |
Sorry about that. I was thinking Mamba Max.
