02-09-2007, 09:43 AM | #1 |
Rock Crawler Join Date: May 2006 Location: United Kingdom,Scarborough
| Need help with Airtronics 94359Z servo
HI i have a Airtronics 94359Z on my Crawlerstore stick chassis for the front steering and when i turn the servo by the controller. It seems to have plenty of torque but it struggle's to center back and when i go in reverse i cannot get it to turn left very well. i have tryed new servo horn and 2 different battery packs. i am running clodbuster axle's,masher 2000's with no weights in the tyres 9.6v battery with 6v rx pack. Tekin rebel2 55t lathe motors. Thanks for any info given. James |
02-09-2007, 09:50 AM | #2 |
Thats odd. You say it struggles to return to center. Is that on flat ground? Did you pull the red wire from your ESC plug that hooks to the reciever? If you didn't,that might be it. |
02-09-2007, 09:53 AM | #3 |
yeah it struggles on flat ground but when i lift the truck up it center's back. i tryed the red wire out but then my truck wouldn't do anything so i put it back in and it worked. Thanks james |
02-09-2007, 09:58 AM | #4 |
Without the red wire,it didn't work????? Did you have the RX battery pluged in at that time? The whole reason for pulling the red wire is for using an Rx pack. With the red wire in play and a Rx pack together.....you'll burn the BEC out of your ESC If you've tinkered with it much with both in play,your BEC is probly toast. Your kinda stuck running an Rx pack now unless you can send it for repair ANY servo will struggle at times....even in easy spots. Your having power issues here,it's obvious to me. Low power will result in poor servo performance Last edited by Reflection; 02-09-2007 at 10:01 AM. |
02-09-2007, 10:15 AM | #5 |
i have tryed to fully charged batterys and rx packs. it struggles on tiles |
02-09-2007, 10:28 AM | #6 |
My 10 year old struggles to understand the way wires work.as do I sometimes I'm not saying you are,just explaining my situation. These are the steps I tell my son to take getting his truck ready for a run. This is with the red wire pulled Charge both batteries (main and Rx) Plug main pack in but leave the Rx alone. Turn the switch on the ESC to the on possition(when the light turns on) Now plug the Rx pack into the reciever. I have to remind him to watch the possitive and negative with this one Install body and clips and burn rubber If you follow these steps,it should work like a champ. My sons Twin was running a TR2,2 359's,27t stock motor,a 6,7 or 8 cells main pack,6v Rx pack and Moab XL's. Following these steps,his always worked great. He is now running a Super Rooster but nothing else has changed and it works good We do have a couple Rx packs out there that refuse to take a charge. Don't rule that out yet |
02-09-2007, 10:30 AM | #7 |
| Update
i have just took the red wire out of the esc connector and it only runs when i turn the rx pack on AND the esc switch on. Can i run my truck like this or will i fry something? Thanks james |
02-09-2007, 10:33 AM | #8 | |
Do the servo's react well? I think you might have posted when I posted. Did you read my steps above? | |
02-09-2007, 10:39 AM | #9 |
yes we posted at the same time. i have followed your steps. And now my servo struggle's really bad to tun left but not right GRRRRRR THIs is getting anoying. |
02-09-2007, 10:46 AM | #10 |
I'm at a loss here. All 3 trucks out in the shop right now run basically the same. A 359 on each axle,ESC with the red wire pulled and 6 volt Rx pack. I use the same steps as above to run them and they always work well,unless a Rx pack fasle peaks. Are you sure theres nothing in the steering linkage in a bind,trim is set near center and nothings in a bind at the knuckles? Sometimes trim can goof things up. You might try to remove the servo arm,set trim at center and reinstall the servo arm. If the trim is all the way to one side,it might be trowing a monkey wrench in there Last edited by Reflection; 02-09-2007 at 10:48 AM. |
02-09-2007, 10:48 AM | #11 |
Rock Crawler Join Date: May 2006 Location: Surrey, BC, Canada
Maybe take and post a pic or 2 of the front end... That may help someone tell what's goin' on...
02-09-2007, 10:50 AM | #12 | |
Say what? | |
02-09-2007, 10:51 AM | #13 |
nope nothing binding and the steering horn is center. i am going to charge a rx pack now and i will let you know what happens later tonight. i have just put a new 9.6v in and see what happens. i am running a Hitec 5645mg for the rear steering but that seems to work fine. Thanks james Last edited by Moondust1950; 02-09-2007 at 11:12 AM. |
02-09-2007, 10:53 AM | #14 | |
02-09-2007, 10:55 AM | #15 | |
Try removoving the servo arm from the servo,recentering the trim knob and then reinstalling the servo arm. That'll put everything back to the centers and eliminate that factor. | |
02-09-2007, 01:00 PM | #16 |
| Bit Of An Update
well just charged my rx pack up and re-wired my receiver. Its stop glitching and the servo seems to be working better. i have being running the red wire out of the esc wire with the esc turned ''on'' and the rx pack turned ''on'' . will it still work ok with both of them turned ''on''? Thanks for all your help so far. James |
02-09-2007, 01:02 PM | #17 | |
02-09-2007, 05:55 PM | #18 | |
02-10-2007, 02:26 AM | #19 |
| i am using 2700mAh rechargeable batterys so it shouldn't be a problem. Thanks for all your help james |
