Thread: CC Slate Motor Selection
Old 07-08-2018, 09:03 AM   #1
Default CC Slate Motor Selection
I have a 1900kv and a 2850 kv. I just picked up an exo terra and I was thinking about running the 1900kv on 4’s vs the 2850 on 3’s. Anybody have an opinion? I’m guessing neither is an ideal motor because of the shorter can but it’s what I’ve got.
dpcardoza is offline   Reply With Quote
Old 07-08-2018, 09:16 AM   #2
Default Re: CC Slate Motor Selection
That make sense 4s on lower Kv
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 07-08-2018, 06:28 PM   #3
I have the 2850kv and the 3800kv slates my. Buddy has the 1900kv and the 2250kv slate id prefer the 3800kv for speed she was a beast for a mud pig. I run the 2850 on 3s and theyres tons of power gear for 80/20 i couldnt imagine on 4s. Are u running a mamba x? If so make sure the motor temp cutoff is 180*F then ur safe for pretty much any kinda testing
Sent from my LG-M703 using Tapatalk
jokersinsanity is offline   Reply With Quote
Old 07-08-2018, 07:30 PM   #4
Yeah mamba x. Heat is what I was worried about with the 1900 on 4’s. I’m not 100% sure but I that I read these motors were tuned for crawlers and not necessarily speed because of the slightly shorter rotor. Similar to the Holmes stubby.
Old 07-08-2018, 08:08 PM   #5
Like i said hook up the castle and set the motor temp cutoff for 180*F and u should be safe for testing at least
Old 07-08-2018, 08:53 PM   #6
More voltage is always better,.
whitrzac is offline   Reply With Quote
CC Slate Motor Selection - Similar Threads
slate motor pinion shaft diameter? cerpindicular Axial RR10 Bomber 13 01-20-2018 08:26 AM
AX-10 Blank Slate: What Motor/ESC & Gearing? Robb Newbie General 2 12-24-2007 11:23 PM
