09-19-2018, 12:08 PM | #1 |
RCC Addict Join Date: Mar 2018 Location: Ocala, Florida, USA
| Cuttable LED strip for rock lights
I have been looking into making my own rock lights. I was just curious if anyone had used the cuttable LED strip. if so what type & are you happy with the results? My LHS has a few different rolls of it for $10 a foot. Just wanted to check with you guys before I pulled the trigger. Thanks for any and all info
09-19-2018, 12:33 PM | #2 |
Rock Stacker Join Date: Aug 2018 Location: Orlando
| Re: Cuttable LED strip for rock lights
Working on similar projects. You need to find out the ratings do some math get some resistors, trial and error YouTube is your best friend and Alibaba Express Sent from my SM-G965U using Tapatalk |
09-19-2018, 12:46 PM | #3 | |
RCC Addict Join Date: May 2015 Location: Price Twp.
| Re: Cuttable LED strip for rock lights Quote:
Yep work great at 12v and water proof | |
09-19-2018, 01:59 PM | #4 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
I bought a whole 5 meter strip of stuff designed to run directly off of 12V (resistors are built right in) for less than your hobby shop sells a single foot for. The vendor I bought mine from doesn't list it anymore, but here's the same thing: https://www.ebay.com/itm/Colorful-Wa...r=500652220417 If you run a 3S system, the 12V strip makes life easy. I tend to prefer to run all of my LEDs directly from my battery. |
09-19-2018, 02:42 PM | #5 | |
09-19-2018, 03:00 PM | #6 |
There you go, taken in absolute darkness and no flash Sent from my SM-G965U using Tapatalk |
09-19-2018, 04:13 PM | #7 |
Quarry Creeper Join Date: Aug 2018 Location: calgary
Very cool, i have a roll coming from Hobbyking i got as a filler to get free shipping. I also picked up a mini 3s lipo that will fit in the front tray of my trx4 bronco and will run it directly off of that with other accessories.
09-19-2018, 04:53 PM | #8 |
From amazon reviews, it seems like many of the strips have solder joints at cut zones every 3rd light or so that are fragile. Just something to be aware of.
09-19-2018, 06:19 PM | #9 | |
No they are not. There is a cut line every 3 lights. That cut line splits a pair of copper pads. All of it is covered in flexible, clear silicon covering. The pads are very small, and admittedly hard to get the silicon off to solder on. I messed up a few getting the silicon off. After I figure out a sharp knife cut above, then a twisting motion to strip away I didn't damage any. Anyway here is an even better and brighter way. https://www.ebay.com/itm/5x-White-CO...EAAOSwRUhY9xZp They come in lots of shapes and sizes. | |
09-19-2018, 11:26 PM | #10 | ||
Happy however its not an issue for you. But don't assume they are all going to be like that. If you only use short 3 light sections at a time it dosen't matter any how. Also many users reported that they weren't waterproof for more then a few days. Maybe in an RC they would never see enough water to matter, but again be aware of it. I do like the LED's you found on ebay, I ordered a set, not sure what I will use them for but that's a good price. Last edited by Voodoobrew; 09-19-2018 at 11:35 PM. | ||
09-20-2018, 04:54 AM | #11 |
I have the black light strip and the white strip the black light makes awsome rock lights and interior lights i painted my skully driver floresent green he lights up nice and bright under black light even in full sun i found them very easy to work with i havent had any sections go out yet in almost 2 years i use both white and black lights in my diy light bars the purple looks awsome haloing the white light
09-20-2018, 05:58 AM | #12 | ||
These small COB lights are GREAT for DIY light bars and bumper lights though. | ||
09-20-2018, 06:51 AM | #13 | |
I run red for both those reasons on my G6/trail truck. However both good points. Having an one off switch is almost mandatory to use them. Last edited by Ditchrat; 09-20-2018 at 06:53 AM. | |
09-20-2018, 07:56 AM | #14 |
Thank you guys for all of your responses! Ditchrat, are those the 3 LED or the cob that you have on yours? That thing is lit up! I was thinking the 3 LED strips that you cut off the roll would be perfect. One strip per wheel well. I've been looking at the cob style for making a light bar. From what I've read about the cob style can get extremely hot & I rather not have that heat in my fender wells. I've been looking for a small cob like 1"-1 1/2" long to put it on my bumper inside my stinger for protection. No luck yet. Sent from my SM-S975L using Tapatalk |
09-20-2018, 08:01 AM | #15 | |
Sent from my SM-G965U using Tapatalk | |
09-20-2018, 10:07 AM | #16 | |
Keep in mind that there's a minimum voltage that those COB LEDs work at, and even at that voltage they can be pretty bright. The only good way to dial back the light is with a PWM signal. | |
09-20-2018, 10:10 AM | #17 | |
09-20-2018, 01:06 PM | #18 |
Just found a company with a really nice product. Flexfire LEDs I talked to a guy there. He said the ultra bright 12v strip would work for what I'm after. It's cuttable every inch. 3 LED per inch. He wasn't sure how they'd do at a lower voltage tho. They are also fully waterproof.
09-21-2018, 10:15 AM | #19 |
Rock Crawler Join Date: May 2016 Location: SoWIs
Heat really depends on if they were designed for true 12v or a 14v automotive app. I've used the non-COB strips for years now and they still work fine. I'd recommend the IP67-rated kind with the thick silicone coating or the kind that come bonded to aluminum inside rails. Also note that the common type is 3 LED/segment, which is usually 60 LED per meter. They make less dense 30/m and up to 120/m and higher. The best value tends to be "5050" size LED chips.
Cuttable LED strip for rock lights - Similar Threads | ||||
Crawl Space Comp Spec LED rock lights | The Crawl Space | Vendors Electronics | 34 | 12-09-2015 09:38 AM |
LED Rock lights | SASDakota | General Scale Talk | 8 | 11-07-2010 11:18 AM |
LED rock lights installed...PICS!!! | iflyos | General Crawlers | 2 | 08-26-2005 06:05 AM |
