11-12-2018, 02:33 PM | #1 |
Newbie Join Date: Jul 2018 Location: US
| Can I use a different charger to charge a Traxxas battery?
I got a trx4 and I bought a lipo battery for it and when I called the traxxas help hotline to ask them the recommended safety timeout for my battery and they told me not to use a different charger other than the id charger from traxxas. Is this true or can I still run a different charger for the battery? Sent from my B1-770 using Tapatalk |
11-12-2018, 02:48 PM | #2 |
Quarry Creeper Join Date: Feb 2018 Location: Melbourne Australia
| Re: Can I use a different charger to charge a Traxxas battery?
Hi, All lipo capable chargers have the possibility to charge all lipo batteries. The charger needs to have compatible connectors for it to work. Does your battery have a separate balance plug? as in it has the main connector, and then a secondary connector with several wires that are used for balancing the lipo cells. I also recommend watching a youtube video on lipo basics and safety. |
11-12-2018, 04:56 PM | #3 |
You will need a balance adaptor to charge Traxxas batteries. I have a Hitec dual charger that balance charges my Traxxas batteries using the adaptor Hang up and Drive |
11-12-2018, 05:16 PM | #4 |
I literally just realised this solved the problem. Part # 2938 from traxxas. Sent from my B1-770 using Tapatalk |
11-13-2018, 10:12 AM | #5 |
Rock Crawler Join Date: May 2016 Location: SoWIs
Fun fact: lipo's don't EXPLICITLY need to be balance-charged. Same as you don't need a crash helmet to drive a Toyota Corolla to the edge of your driveway, but both will increase safety. You balance the batteries so you don't over-charge/charge a weak cell. A good battery won't have a weak cell & need virtually no help from the balance circuit. Lately I've been leaving my ISDT charger in fast-charge mode that results in minimal balancing and just set cut-off to 4.15v. That little bit less will result in 30-50% more charges, as well as never charge an individual cell past 4.20v. |
11-13-2018, 08:00 PM | #6 | |
| Re: Can I use a different charger to charge a Traxxas battery? Quote:
Exactly! https://www.rpphobby.com/product_p/tra2938x.htm | |
12-01-2018, 12:41 PM | #7 | |
| Re: Can I use a different charger to charge a Traxxas battery? Quote: Sent from my B1-770 using Tapatalk | |
Can I use a different charger to charge a Traxxas battery? - Similar Threads | ||||
Can I charge a 7.2 battery with a 11.5 charger? | donny8594 | Newbie General | 8 | 02-11-2014 03:02 PM |
Discharge/Charge battery charger. | MOfroggy | Electronics | 17 | 10-25-2007 10:38 AM |
can i use stock batter charger to charge NIMH battery? | limegreentj | General Crawlers | 2 | 01-05-2007 06:12 PM |
