02-21-2005, 11:22 AM | #1 |
Pebble Pounder Join Date: Mar 2004 Location: Griffith
| CS80 problems!!!
I just got a cs80 servo. I am using it with an evx and stock reciever, also running two batts. Ok When I plug the servo directly to the receiver I can turn the servo but when turned all of the way either direction I am not able to move forward or reverse. Next problem. When I plug an RX pack into the Y harnes that comes with the servo I can turn awesome, but the truck will not move at all. This is getting really annoying thinking about tgoing back to the 645's if I cant fix this. Any suggestions? Craig |
02-21-2005, 12:15 PM | #2 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
when its all plugged into the y-harness and stuff, try to unplug the red wire from the EVX that goes into the reciever.then see how that runs :? i know it helped me out doing that
02-21-2005, 12:58 PM | #3 |
Yeh I will try that. And I will get those pics to you tonight soon as I get off of work.
02-22-2005, 07:20 AM | #4 |
Well it looks as if that worked......but why? Craig |
