01-25-2019, 02:24 AM | #1 |
Newbie Join Date: Nov 2018 Location: Hungary
| Tekin 55t HD mounting hole question
Hello Guys, I know that maybe this question sounds noob but I never dealed with a Tekin motor before... Can somebody tell me that why are 2x2 mounting holes on the Tekin brushed HD motor and which hole to use on the Tamiya CC01? Thanks in advance, TDanny |
01-25-2019, 02:59 AM | #2 |
Quarry Creeper Join Date: Dec 2010 Location: Pontypool, wales
| Re: Tekin 55t HD mounting hole question
The extra holes found on motors are for individual mounting preferences to the motor mount , for example find the basic desired orientation of motor so wires are directly above or to the left or right then there should be a fixing hole reasonably close to that at top dead centre of motor mount , fix that screw finger tight so it can still be moved then line up the bottom hole according to the tooth count of the desired pinion Hope this helps Sent from my iPhone using Tapatalk |
01-25-2019, 06:39 AM | #3 |
Basically what willyg said but I would just like to add be sure you use the holes that are directly across from one another. I'm sure more than a few of us have installed a motor using the wrong mounting hole on 1 side and wondered why the gear mesh wasn't working.
01-25-2019, 06:51 AM | #4 |
Good point svt923 , very important !!!needs to be directly opposite the top screw for perfect gear mesh !!! Sent from my iPhone using Tapatalk |
01-25-2019, 02:22 PM | #5 |
Thank you guys, it worked well. The mounting holes are pre-set on the CC01 motor plate so there was no need to set gear mesh. Thats why it was impossible to miss the holes thanks god...
Tekin 55t HD mounting hole question - Similar Threads | ||||
Chub mounting hole stripped? | Scurvy | Axial Wraith | 4 | 09-17-2012 07:58 AM |
Novak 55t or Tekin 55t Mach Wound | Stein | Electronics | 2 | 07-15-2009 06:28 PM |
Tekin 55T Question | MDcrawler72 | Electronics | 2 | 12-10-2008 12:38 AM |
Scorpion 2215 mounting hole depth? | NickRummy | Electronics | 2 | 08-24-2007 05:48 AM |
