02-04-2019, 12:45 AM | #1 |
Quarry Creeper Join Date: Feb 2006 Location: Surrey B.C Canada
| Servo V Q?
I just picked up a hitec 7980TH for my xr10 I run 3 cell ..the servo says it's designed to run 7.4v Am I safe to throw it on? Thanks in advance 🍻 |
02-04-2019, 01:16 AM | #2 |
Quarry Creeper Join Date: Apr 2018 Location: US
| Re: Servo V Q?
Should be fine, your servo should be powered by the receiver. The ESC is what powers the receiver, via the BEC. Most ESCs are only 6v, possibly up to 7.4v. Sent from my Pixel 2 using Tapatalk |
02-04-2019, 01:26 AM | #3 |
| Re: Servo V Q?
Appreciate that..Thank you |
02-04-2019, 04:22 AM | #4 |
Rock Crawler Join Date: Jan 2019 Location: Calgary
| Re: Servo V Q?
Operating voltage range is 6.0 - 7.4 volts Stall current draw is is 9.9 amps You need a Bec capable of that voltage range and current draw, a cc Bec would be perfect. What ESC are you using? |
02-04-2019, 08:56 AM | #5 | |
Pebble Pounder Join Date: Mar 2007 Location: Northern Ontario
| Re: Servo V Q? Quote:
It will work without an external BEC right up to the point where your ESC's built-in BEC can't supply the current the servo needs. When that happens you'll get brown-outs or jittery steering. Try it without the BEC first, you might be fine if you don't get into situations where you bind up the steering. But I wouldn't count on it. | |
Servo V Q? - Similar Threads | ||||
C.I. - Servo Guard - Servo Clamp - Servo Mount - Annoucement | Nova's Ark | Crawler Innovations | 10 | 05-07-2015 01:25 PM |
***Crawler Innovations Engraved Servo Guard-Servo Clamp-Servo Mount GIVEAWAY*** | Nova's Ark | General Crawlers | 106 | 10-20-2013 02:16 AM |
***Crawler Innovations Servo Guard-Servo Clamp-Servo Mount GIVEAWAY*** | Nova's Ark | General Crawlers | 228 | 07-12-2011 01:17 PM |
***Crawler Innovations Servo Guard-Servo Clamp-Servo Mount GIVEAWAY*** | Nova's Ark | General Crawlers | 266 | 04-01-2011 02:18 PM |
Crawler Innovations Servo Guard - Servo Clamp - Servo Mount GIVEAWAY!!! | Nova's Ark | General Crawlers | 219 | 10-18-2010 12:43 PM |
