Re: New Crawlmaster Sport 540 and 550 motors! I sent them an email to alert them to the new products. Not sure if they've ordered. If customers would email they will act quicker |
Re: New Crawlmaster Sport 540 and 550 motors! FYI, RPP has them in stock. I ordered a 15t 550 earlier in the week and it arrived yesterday. |
Re: New Crawlmaster Sport 540 and 550 motors! Hi John, I want to order one of these soon for an SCX10-II raw builder’s kit. I was looking at the chart on your site and see that the Crawlmaster Sport 540 16T is compatible with the stock gearing on the SCX10-II kit and RTR. Would a 550 12T also work without changing the gearing? The KV is a bit higher, but not much. Thanks for your help. |
Re: New Crawlmaster Sport 540 and 550 motors! Quote:
Sent from my Pixel 2 using Tapatalk |
Edit: or maybe 3s is overkill, I’m just looking for smooth, low speed performance, don’t care as much about speed. |
Re: New Crawlmaster Sport 540 and 550 motors! Totally fine on 3s |
Re: New Crawlmaster Sport 540 and 550 motors! Thanks John, brimdogg. 550 it is. Can’t wait to install it. |
Re: New Crawlmaster Sport 540 and 550 motors! Still nothing on amain. But rcmart has the 540 13T and the 550 12T in Stock. Holmes Hobbies CrawlMaster Sport 540 13T Electric Brushed Motor #110100097, Holmes Hobbies CrawlMaster Sport 550 12T Electric Brushed Motor #110100100, |
Re: New Crawlmaster Sport 540 and 550 motors! I want to order Crawlmaster Sport 550 12T for my TRX-4 Sport kit build. Will it be compatible with Hobbywing 1080 ESC, on 3S? |
New Crawlmaster Sport 540 and 550 motors! What is the right 540 can to fit the capra? I have a Castle sidewinder 4 ESC but I don’t want to spend too much money on the motor since I read these new crawlmaater sport is more than enough. I have a revolver and an yellow jacket which I use in my Toyzuki because of the fitting, and I really hate how they rumble at low speed. Any advice? |
If you need more speed than that, I'm sure the 13t is still a great choice. Sent from my Pixel 2 using Tapatalk |
Re: New Crawlmaster Sport 540 and 550 motors! Just ordered a 540 16t. Never used a brushed motor before so hoping this gives me good torque with some wheel speed on my C2 build! Going to start it off on a HW 10BL60 WP which i have lying around here and if its not up to par, will get a 1080. EDIT: well upon researching this ESC, it seems it can't switch between brushed and brushless. Looks like I will be getting 1080! |
I just got the 20t, maybe I can get a little more speed with a higher teeth pinion, what do you recommend? |
Re: New Crawlmaster Sport 540 and 550 motors! Hey John. I'm going to pick up one of the new 12T 550 Crawl Master motors for my trx4 sport. I'm going to order the motor from my LHS with the wire leads. What size bullet connectors do you use on your wires? Thanks Sent from my LM-G710VM using Tapatalk |
Re: New Crawlmaster Sport 540 and 550 motors! 4mm |
Re: New Crawlmaster Sport 540 and 550 motors! Motors finally arrived and I replaced the 27t 540 trailmaster sport with the 13t 540 crawlmaster sport. I did not change anything else and ran it with the old and new motor on my little test track. The difference is huge. I expected a difference of course, but it is much bigger then I thought. The control and smoothness in combination with the 1080 esc is brilliant, especially for such a price tag. Looking forward to compare the 21t 550 with the 12t 550. The little HH stickers are cool :) Gesendet von meinem TA-1004 mit Tapatalk https://uploads.tapatalk-cdn.com/201...7cb971afeb.jpg |
